HOSS 3.0 Fox Suspension height higher than the Bilstein suspension? Fits 37" tires?
Montducati
Montducati
CT
2016 GT-350, 2020 BMW M2
Looks good Rk! It appears you still have decent clearance as well. Any off roading I do will not likely push the travel to the point of rubbing.
tzelko
Tom
Birmingham, Alabama
Bronco Wildtrak
I have my Hoss 3.0 2 Door for 2 weeks and I don't this it is any higher than other Sasquatched Broncos. Just better. :)
Paul, how's the ride on pavement with the HOSS 3.0? Ive heard its significantly better.
Paul113
Paul
It definitely is better on pavement from the standard Wildtrak I’ve driven before.
Montducati
Montducati
CT
Nice, I’m glad I added the 3.0 to my build even though it will probably delay my delivery by 6 months 😂
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Thanks!
Yeah, like I said I cant find any rub marks, and havnt heard any rubbing while driving, including full U turns. Ill test it out off road when it cools down a little. I may do the JKS max tire clearance kit, or a hybrid of my own depending upon if and where it rubs off road.
Plus like I said I have the Zone level to put on the front, though I may do the front perch collars, as im not a fan of the nose dive while braking hard.
Post pics of yours once you get it done...
Redcobra
Tony
Massachusetts
2018 Expedition, 2020 Escape, 1970 Galaxie XL Conv
Any lift you add will probably void a lot of suspension-related claims, depending on the dealership. Similarly, adding 37s will probably do the same thing and a bit more.
Sounds fishy they would void the warranty when "LIFT ME BABY" is embossed in the front fender liners??!! By the manufacturer no less! I am only doing what I was asked to do!
RainbowStix
A Big Island
Toyota Tacoma
Good luck telling that to a dealership🤣
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
Any negative side over time to adding spacers? Will it void any Warranty?
Spacer lifts are hard on upper arm ball joints. Ford is known for having weak upper arm ball joints to begin with. IMHO, I would never run spacers. Seen way to may broken parts caused by them.
Most people that run them also tend to run an aftermarket upper arm to fix this.
