How to check transmission oil level (no dipstick)? Mileage to change engine and transmission oil?
Mpali
Illinois
2022 Wildtrak
Anyone can tell me how I can check the trans fluid level. Is there a dipstick that I cannot find? Also, how many miles for trans filter and oil change?
grayshadow
Charles
Humble, Texas
You should go to a Ford dealer and ask the “service manager” or read the “owners manual”.
broadicustomworks
Hanging Rock, North Carolina
OR we could use our energy to be helpful.
There isn't one. It is checked with a fill/check plug in the side of the trans - similar to how a manual trans would be filled/checked. It supposedly has "lifetime" trans fluid in it.
Typically if there are trans issues or suspected fluid issues, take it to the dealer to see if it needs a flush-n-fill.
Mpali
Mpali
Illinois
2022 Wildtrak
Thanks for your reply
mini4mw
W
Atlanta
Tundra
I've read some jeeps that have the same thing but they are completely sealed and then blowup bc the trans fluid is jello. Need to find/check the definition of lifetime. It could be 10yrs. Either way I'd still change it at some point, perhaps every 50k.
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
Additional info. #reserved.
Breather/vent cap? How about if so does it have anything to do with the fjord water level? Good question for an engineer or someone that's been on top of the auto trans. We are talking auto trans right?
da_jokker
Jeep Wrangler JKUR
Yeah I hate that they don't give us any means to check the fluid status or level. I mean how you supposed to know if some water got in your transmission or something.
My mother-in-law has a Mercedes, and they seal the dipstick tube to the transmission. You basically have to break off the seal and purchase a special Mercedes tool (aka a dipstick) to check its level.
..... And don't believe there's a lifetime fluid crap. It's all marketing. What they really saying is lifetime for the warranty period!
Denny Swift
Earth
718 Spyder, 992 GTS, Citroen 2CV, Husky FE350
If it's not leaking, there really is no need to check it. There is no place for the oil to go. But if you want to....
Ford Bronco How to check transmission oil level (no dipstick)? Mileage to change engine and transmission oil? Screen Shot 2022-11-18 at 9.17.38 AM
Ford Bronco How to check transmission oil level (no dipstick)? Mileage to change engine and transmission oil? Screen Shot 2022-11-18 at 9.24.02 AM
SuperFord
2013 Ford Fusion
You shouldn't need to check your transmission fluid unless it is leaking or the transmission is acting up.
As Denny Swift said above, the factory transmission fluid interval is 150,000 miles (not "lifetime").
Having said that Ford stops warrantying the transmission at 60,000 miles so you may want to opt to start servicing it then.
orion
Jeremy
17' F-250, 17' Explorer
If I had an auto, I would change fluid and filter at 30k, fluid only at 60k, then fluid/filter at 90k and keep that routine up.
Yo won't be draining all the fluid but you will be adding clean fluid to what is stuck in the lines, torque converter.
That's what I'm doing with our Explorer and Super Duty...
internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
Thanks for posting this, I'm wondering how this will be affected by towing a lot. We pull our 3200lb travel trailer a lot so I'll definitely be keeping an eye on the transmission and diff fluids.
Ducati1098
This post is a little old, but for future reference if anyone else looks for this information… I’m not sure why everyone said there is no dipstick, because the 10R60 does have one on the left side of the transmission. It’s not just a plug, it has a small dipstick for checking the level.
Ford Bronco How to check transmission oil level (no dipstick)? Mileage to change engine and transmission oil? F8B65512-2CC5-40C7-ABCB-75A945F783D0
Bosco24
24 Outer Banks
Thanks old school doesnt apply any more
LSW
L
North
'24 Bronco Wildtrak
Does anyone have the part number for the 10r60 transmission dipstick/19mm bolt. I buggered the aluminum bolt/cap up during my self-service transmission fluid and filter change and while it still works, would like to replace it.
