kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
BCHBRNC22
Virginia Beach
2022 Ford Bronco
No offense, but this is a solution looking for a problem. I have put 1000s of miles at highway speeds without issue.
davidforlife
davidforlife
Atlanta, GA
BadManSquatch
Hey no offense taken. I get your point, but when I said secure, I really meant “more secure”. I ran front panels without the back for months and didn’t like that I could physically see a gap between the two unlatched corners. I could see it from across the parking lot. It looked crooked. Problem #1 solved. #2 I wanted better mounting points for a partition between front and back seats. Not gonna lie, it does give me piece of mind, so maybe you got me there. Regarding highway speeds, it never was my concern. I don’t even think I use the words “highway” or “speed” in my post. Guess I need to clarify. I was never good at thesis papers.
davidforlife
davidforlife
Atlanta, GA
BadManSquatch
Tofudude
Chan
22 Brono Base Mansquatch
I’ve been wanting to do this but was afraid of the panels flying off or someone walking away with them . Stealing this idea with some mods now lol
pandapaul
Paul
Tallahassee, FL
2021 Badlands Sasquatch
My ultimate plan is to build a tonneau cover and add a soft “window” to separate the cab from the back seat, so the crossbar will also function as mounting points for the window.
I cannot wait to see that come together! Side note, please message me if you're ever in Tallahassee!
JKMor
Jaime
Long Island, NY
2023 Bronco 2 door
When you say “make a tonneau cover and add a soft “window” to separate the cab from the back seat”, that’s exactly what I want!! I was wondering if the tonneau for the 4 door could be modified to go all the way up to the front seats on the 2 door🤔 Let me know if you ever decide to sell/install these ideas👍🏼
Bad To The Stone
Bud
2023 Badlands;2015 Hellcat;2016 F150
Love this mod and was planning to do the same when my Bronco comes in. I also was hoping to do the tonneau division. Or maybe even an aluminum plate with a window? Thanks for sharing the post. Glad to know there are some easing mounting points to make this work.
Dantastic
Daniel
Lake Saint Louis, MO
www.youtube.com
OBX Sas Bronco, Mazda CX-5
It’s secure but not solid. They’ll flex if you push up on the panels. In short term they’d be fine, but you may start to see some cracks in the panels over time. My ultimate plan is to build a tonneau cover and add a soft “window” to separate the cab from the back seat, so the crossbar will also function as mounting points for the window.
I look forward to seeing the follow up post!
BroncoEnvy
Jonathan
2022 Bronco Badlands 2dr, 2006 F250 FX4
I know this is a little off topic, but I wonder if it would be possible to run the mid panel from the 4 doors on the 2 door if one were to switch the brackets on the top of the roll cage that the panels interact with. Would be an interesting way to create a safari style hardtop on the 2 door. :unsure:
Thinking further out of the box, it would be interesting to then add some removal soft side and rear windows like on the soft top... :unsure::unsure:
Ford Bronco How to get "half cab" look on 2 door Bronco using a DIY crossbar top brackets 2dr
Ford Bronco How to get "half cab" look on 2 door Bronco using a DIY crossbar top brackets 4dr
93_SVT_3503
JJ
BFE
2016 F150, 1967 Bronco U-14, 1993 Mustang Cobra
Back in the 90s there were a few different variations of the tonneau covers made for the 5G Broncos with the top off. I'm sure someone will eventually come out with one similar.
Ford Bronco How to get "half cab" look on 2 door Bronco using a DIY crossbar 1694529287198
Ford Bronco How to get "half cab" look on 2 door Bronco using a DIY crossbar 1694529319464
Ford Bronco How to get "half cab" look on 2 door Bronco using a DIY crossbar 1694529471517
This company might still be making things as well;
http://www.skylercorp.com/Skyler-tops.htm
davidforlife
davidforlife
Atlanta, GA
BadManSquatch
Your idea looks sick in my head. A few of my neighbors have 4 doors 🤔
