I previously thought they came with a class 2 hitch based on the 3500 lb limitation, but after seeing that it’s mounted to the rear cross member (presumably to maintain departure angle) I can understand the limitations. A full receiver mounted to the frame rails, coupled with some sort of spring assist should easily push the rating higher. Not trying to argue anything, only stating what I think can be done, warranted or not.
