pretty sure the front locker is only on the M210 which is why I am leaning towards if I dont go BL standard, go BD with sas
Base says rear locker included with sasquatch, no mention of a stand alone option.So when you look at this sheet it makes it look like only Rear locker is available for Base, Big Bend , Outerbanks without Sasquatch. If you want Front yoy have to get the Sasquatch. So basically without Sasquatch you can have a rear locker by itself all the way up to Outterbanks. Black Diamond is standard though.
TheIf you select the power and handling section in options it says locking front and rear axle. I didn't go through all the models but it says this under the Base model and Big Bend for sure.
So it looks like you don't have to get the Sasquatch package to get fromt and rear Lockers.
You can upgrade the Big Bend and Outer Banks to rear lockers only, same as included in the Black Diamond. There is NO option to upgrade any lockers on the Base model. There is no option to upgrade front lockers on any model.If you select the power and handling section in options it says locking front and rear axle. I didn't go through all the models but it says this under the Base model and Big Bend for sure.
Yeah I saw that now. Im hoping Sasquatch is affordable for the Base model. If so thats the direction I'm going. If not i might just get the Black Diamond.The
Given that the Black Diamond and Badlands already have some Sasquatch parts, we should see different Sasquatch prices depending on model.
Choice #1) Black Diamond - 4Dr, 2.7L, hard top, 33" tires & Cyber OrangeYeah I saw that now. Im hoping Sasquatch is affordable for the Base model. If so thats the direction I'm going. If not i might just get the Black Diamond.
He said "most" not "all". As much as I want to see it on the Base I don't think it will happen. Rear locker as standalone would be the only reason I am considering the BB. Don't like having to pay $4500+ to move up for the privilege of paying even more for the locker. Other option is aftermarket probably after out of warrantyI thought Levine answered during the Q&A that rear locker is available as a stand alone on all models that don’t have them standard, but front is not (i.e. front only comes with Badlands or Sasquatch).
I'm #1) Base + Sasquatch 2 door 2.3 AntimatterChoice #1) Black Diamond - 4Dr, 2.7L, hard top, 33" tires & Cyber Orange
Choice #2) Base - 4Dr, 2.7L, Sasquatch, hard top & Velocity blue
I wonder which setup will cost more? I really want the orange.
All are selectable e-lockers. No limited slip. These days the computer limits wheel slip by apply brake to whichever side needs it. If I wasn't getting a rear locker, I'd rather have something like a Detroit Truetrac than the computer, but those days are gone unless you do it yourself.Are the available 'lockers' all the type where they can be engaged/disengaged ('electronic diff locks'), or may some be the old posi-traction/limited slip style?
There is an aftermarket ARB air-locker avail for the Ranger. Models for the Bronco are sure to follow:
https://www.stage3motorsports.com/R...ng-Rear-Differential-OEM-Open-Diffs-Only.html
Has anyone seen any evidence that Sasquatch includes the M210 front differential upgrade? It seems like the pinion size on a 7.5" gear set is going to be a weak link with a 4.70 ratio and 35" tires with 400 lb-ft on tap.
I'm a musclecar guy..... applying a brake to the spinning wheel will slow my et! Gimme a limited slip instead!
I may do an aftermarket limited slip for the rear on my base if it's avail somewhere.
