ColonelAngus
Jon
PA
2023 Badlands, 07 BMW 335i, 05 Saab 9-5 Aero
I was thinking the exact same thing! Op has a surprisingly positive outlook 👍🏾
I mean it sucks.. but its just a piece of top and it still attaches.... can make that look half decent... deal with it later.
skater777
Massachusetts
Ford Escape
Sorry for your loss. Is that a MIC top or a cheap piece of laminated particleboard furniture from China?
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
I wonder if the answer depends on how many times you ask the same question.
NotApplicable
BEVs
Bronco attendants, please prepare for cross-check
BigMex
Ezra
Columbus, Ohio
2021 White Ford Bronco (moar door, 7spd, lux)
Great when/if I get my Bronco I will be doing a "pre-flight" checklist.
The checklist is an absolute must.
First world Bronco problems.
I hit my open softtop on my open garage. Thankfully, having the 7 speed manual transmission means I was gently feathering the reverse gear into action, and besides a solid thud, and a wood crossmember with some give, no serious damage was done.
lakesinai
lakesinai
Charleston SC
Welcome to the TOP club!
TwinTurboStang
CT
Brodiak
Thanks for the tip. SEM looks alot like the JB Weld suite of products. How thick is 39747? The first step needs a fairly thin epoxy to inject into the crack and impregnate the fiber, then clamp. The second step requires a thicker gel that can be built up and shaped. I'll probably use JBWeld 2part for the second because its gray is similar to the MIC color.
What the? Mine isn’t a probably, mine is from years and years of repairing SMC, Fiberglas and carbon. But ya if you “think” jbweld will work because of the color sure try that.
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 21 Bronco
Looks like I need a systems checklist for startup! ]
I've made it a hard and fast rule of mine to ALWAYS latch my soft top whenever I put it up. No matter if I think I'm only going in the store for a few minutes and I know I'm planning on riding topless when I leave. If I put the top up (on in your case), I latch it up. It only takes a few extra seconds.
Sucks that it happened. Kudos to your good outlook on it!
Bob Blaylock
Bob
2016 Dodge Dart
You Better wear those battle scars proudly!🤕;)
This resonates well with me.
I caught some flack, in another thread, for dismissing someone's upset over a scuff in his Bronco, by pointing out that I do not expect mine to stay pristine in appearance; I expect it to get dirty, to get scratched, to get dented. Not even based on any expectation of any off-roading I might do with it, and what that will do, but just on the abuse that my current compact sedan has taken in the nearly five years I've had it.
I'm not buying my Bronco to keep as a pampered museum piece. I'm buying it to take out into the rough Real World. A world that includes construction sites with bad terrain, but much worse than that, also includes the traffic and road conditions in Sacramento, the capital of a state that is so deeply corrupt that it keeps jacking up our gas taxes to pay for road repairs, and then, instead of using it to pay for road repairs, lines the pockets of the criminals who infest our government, who then have the excuse to jack up our taxes again to pay for the road repairs that they didn't do with the last round of jacking up taxes for that purpose.
“A ship in the harbor is safe, but that's not what ships are for.” — John Augustus Shedd​
Mean Red GT
Kevin
TN
2022 4 Door Badlands/2016 Mustang GT PP
Do you have a link to that video?
Watch from about 2:20 -2:40. Literally looks like heavy corrugated cardboard inside
lakesinai
lakesinai
Charleston SC
Yes, thanks. That's the kind of systems operating rule I need, a driving habit for this very special vehicle!
andrusoid
Steven
Bend, Oregon
2017 Outback, '79 2G, '89 3G, '92 5G White!
Looks like I need a systems checklist for startup! I took off down the road and once I got up to 45-50 mph on the 3-lane, the driver's side MIC panel blew right off the car! Luckily I was able to pull over, run and retrieve (a driver stopped by the panel to protect it from being run over). Obviously I forgot to lock the latches on my new MIC2 Panel that my OBX waited for almost 3 months on Dirt Mountain.
It still works well (I'll know for sure after today's rain) and now its time for some Epoxy home repair, put my epoxy boat-repair skills to work. That protruding front corner is the worst. Can I assume epoxy will work, or will I need a more exotic panel glue!
I don't imagine buying a new panel is going to be easy . . . Can I get one of those MIC1 panels when replaced? I can attest that they are strong, and I don't think I'll make this mistake again!
Ford Bronco MIC 2.0 Top blew off (forgot to latch)! Pics of damage and material / construction tenor
OMG, particle board, fiberglass and then plastic? Reckon that's cheaper than just good 'ole fiberglass with a gel goat. I wonder if I can find any of my boating buddies from the 90's in Florida that used to copy boat hulls by making a mold from the original hulls.
Now, this might have been done to save wait, but watcho, watch, 'dere be trouble comin' bro.
Sorry this happened to you, nice fix with the epoxy. Maybe you can get some epoxy clay and form over the tip.
andrusoid
Steven
Bend, Oregon
That may have been my post. In reality it is high tech cardboard and not just plain cardboard. And the plastic is molded onto the composite under layer. and not just sprayed on by Phil Swift.
Actually looks like a plastic honeycomb from the videos. The cells are uneven and wonder how they were "grown". Maybe they plasticized flower DNA and fed it to honeybees that pump out plastic honeycomb?
