mootruck98
Kyle
Madison, MS
2006 Nissan Titan
I've been working on my mobile amateur radio install for a few weeks now. Its been slowly evolving as I've been collecting pieces and trying a few different things. I am pretty happy with what I have as of today. Here is what I've come up with.
50 watt Mobile Dual Band Radio install - FTM-400XDR.
Comet SS680SB NMO dual band antenna with lip mount on hood. (mount and cable "borrowed") from my Motorola GMRS kit. The antenna is halve wave on the 2meter band so less dependent on a ground plane. Also this antenna includes a spring so a bit more trail friendly.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_133156
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_133126
Power:
10 gauge cable with inline 40amp fuses connected directly to battery terminals on both positive and negative. Left a little slack in case I decide to add a breaker or relay to control off a switch or anything.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_133240
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_133318
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_133302
Power cable comes in through firewall grommet on driver side then runs behind infotainment system to the passenger side.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211023_141822
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211023_141815
Tucked behind glovebox and infotainment system I mounted a small fuse box that the incoming power cable is connected to.
I used Anderson power pole connectors to to connect the incoming power cable and a pigtail on the fuse box. This will allow for the fuse box to be somewhat easily removed if additional connections are needed to be added to it.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_113536
In addition there are 2 pig tails coming off 15amp fuses from the box for radio use. This FTM-400XDR install and a midland GMRS mobile coming soon.
Ram Ball mount (C size ball with M6 bolt end) fits in the bronco bolt holes from the removed center console grip. Aram arm that goes from C size to B size tucks the radio out of the way.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_113545
Before I put the glove box back on I ran the control cable that connects the base unit to the screen unit. It runs behind the glove box up the A pillar then across the dash to the center accessory mount point.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_114850
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_114902
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_114917
With the glove box back in place the radio could be installed and extra cables cleaned up a bit.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_120622
Not too bad once the floormat covers up the extras.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_120717
This install does block quick access to the glove box, but the ram arm can be easily loosened and rotated to allow access to the glove box.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_120911
It does eat up some leg room on the passenger side, but not horrible for a quick trip around town. Here is my big 6' 1" ~300lb self sitting in the passenger seat for reference. Seat not all the way back.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_121705
Here are some other shots, you will notice another ram ball is available for mounting a midland GMRS radio. This will probably be more of an occasional use radio for out on the trail and will most likely be with an ram arm holding the radio up. as opposed to tucked away as the controls are on the base unit of that radio.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_121231
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_121744
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics 20211113_121818
As for APRS, the pickup truck icon isn't accurate, and neither is the jeep icon obviously. So I went with horse "/e" icon.
Ford Bronco Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics Screenshot_20211113-131053_Chrome
This is my first real mobile radio install, just been using an HT with an external antenna up until now on my old truck. Let me know if I missed something or you have any suggestions. Hope this helps some people out planning their comm installs.
73 de KI5JCL
mootruck98
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
mootruck98
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
For the record Mississippi State was down 28-3 at one point to Auburn. WHO DAT! #FTF
They were able to came back to win 43-34! Clanga Clanga! #HailState
lakesinai
Charleston SC
Power:
73 de KI5JCL
Very cool! So many hobbies and avocations this vehicle inspires and supports!
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
What mount system did you use for the dash top
mootruck98
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
RAM Mounts Tough-Ball with 1/4"-20 x .25" Threaded Stud RAP-B-379U-252025 with B Size 1" Ball
https://www.amazon.com/dp/B00AHCUNG2?ref=ppx_pop_mob_ap_share
RAM Mounts RAP-B-201U Composite Double Socket Arm with Medium Arm Compatible with RAM B Size 1" Ball Components
https://www.amazon.com/dp/B0074WMQLS?ref=ppx_pop_mob_ap_share
HuddExpo Yaesu FTM-400 or FTM-300 1 Ball Mount for Ram Mount Systems
https://www.amazon.com/dp/B08X6KNQFW?ref=ppx_pop_mob_ap_share
ChrisSd
Bay Area, Ca
Base Bronco
Power:
73 de KI5JCL
What adapter did you use for dashboard mounting on the dashboard
Carbon Bronco
Washington
1969 U15 Bronco New Lime 302ci
Now that you have the lengths and routing figured out, protect your conductors with some split loom for a trouble free service life. Also, that's the first time I have seen both positive and negative circuits fuse protected, is that a radio specific requirement?
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
Is there a reason to put a fuse on the negative side? Is this ham radio specific? Novice asking, thx!
edit: you beat me
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'75 Intl D150/'22 Badlands
Radios typically have the negative grounded. Not likely anymore but if the negative battery terminal became disconnected, and presumably the radio was still connected to it, the entire electrical system could ground through the radio. Not as likely anymore because of how the battery connections are done now, but it's still typical practise.
mootruck98
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
RotorOver
Greater Atlanta Area
2023 Bronco Wildtrak, 2021 F-150 Raptor
Awesome! I did FTM-400XDR & Midland MTX-275 installs on my 2021 Raptor recently (documented here) and used the RAM components on the dual band, but installed in different locations. It's great to get ideas on threads like this, so thanks for sharing. Maybe one day I'll get my Bronco!
mootruck98
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
Basically this ^
The manual says to run directly to battery fused on both lines near battery. I modified a little to accommodate multiple radios in future via fuse box.
