Premium fuel!
calgecko
Sacramento, CA
www.instagram.com
2021 Chevy ZR2 Bison V6
I've got the 2.3 in my Mustang - and it's night/day going from 87 to 91. for a difference of about $2.00 per tankful, I don't know why anyone would go with a lower grade fuel.
Studawg
SC
02 Excursion, 96 Land Cruiser, 18 Land Cruiser
Serious question, what is the advantage or the point of getting Ethanol free? Only reason I ask is b/c I am from a big farming community and a lot of people push the ethonal.
The more ethanol the gasoline has in it, the less energy it has, so the less your mpg is. Ethanol-free is going to give you more mpg and increased range.
Hkak45
K
Illinois
21 Bronco Black Diamond
This maybe a dealbreaker for me. Never owned a turbo before. I am not running premium in a DD. Damn it this maybe the end of my new Bronco plan.
I’ve personally seen a Focus ST with 2.0 ecoboost run on regular 87 for 92000 miles perfectly fine. Would have went longer but sold the car. You do not need to put premium in it. Will it run better on premium, yes, but it’s not mandatory as the computer will automatically adjust everything when it senses less than 93 gas.
crowdpleazer
Daniel
West Virginia
Ford Ranger, Honda Civic
On a new vehicle, it's only a small decrease in mileage, as they have components meant to handle the crap.
Older stuff and small engines with carburetors, it is horrible for them. The ethanol absorbs water and causes corrosion inside carbs and gas tanks and very quickly deteriorates fuel lines and gaskets. Something that gets driven often, it's not that bad but something that sits around, like over the winter, it will cause problems in just a few years.
djteotancolis
Shawn
Atlanta
Genesis G80 3.8
Anyone know if it will be compatible with Flex fuel? Not that I will use Flex fuel but in Atlanta, it helps to have it.
DrewBronc21
New York
check out the mustang EB forums for more info, but you would need to upgrade fuel pump, rails, etc. Worth it for people looking to build for more power......Funny how everyone is posting how they want ethanol free gas and I’m thinking how do I get this thing to run on E85! Sure you get worse mpg, but it’s dirt cheap and like 100-105 octane. Been running my Subaru’s on E85 and Flexfuel for almost 10 years. My current STi made an extra 50 Whp and Torque just by going from 93 to E85. Have not had any issues and will definitely go flexfuel on the Bronco as the aftermarket develops.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I have the 2.7 and run 87 most of the time. Here in MI are about 500’ above sea level. In the summer I can detect a difference, but rarely run anything but Costco 87. Boat, See Doos, motorcycles, power equipment all get 89 ethanol free. Hard to find in metro Detroit, but it’s available in most rural areas or where boats are used a lot. Ethanol attracts water and is horrible in any environment where you have moisture. I have used it in my F150 and any difference is undetectable to me. Several downsides to Ethanol in my experience. It goes bad very, very quickly when stored. I have never seen an example where more than 10% ethanol is worth the price difference, net cost when the difference in mileage is calculated. Biggest upside, it does resist detonation better than gasoline, so it can work really well in turbo or supercharged high performance applications, as many have stated.
RG7
B8 A4, 2018 Triumph Street Triple R
It’s a weird dichotomy. I’d rather have either zero ethanol gas or e85 on a setup built to run it. Not interested in e10 junk
ocnorBdroF1202
San Antonio, TX
2018 GMC 1500 SLT
At Rudy's BBQ and they have all grades ethanol free and Murphy's Express has regular that is ethanol free.
QT gas stations also have ethanol free (look for the red handles on the pumps)...that what I run in my '66 Chevelle
andi
Same as my '11 Stang. I always used premium.
I'm not gonna sweat an extra $50-60 at the end of the year.
On the stang I think you lost 10 hp and 15 ft-lbs on 87
Well depending how you drive,
I fill up 48 times a year if it’s a 4-6 dollar difference between fill ups comparing premium to regular, that’s about 300 a year for me.
Again, depends how you drive, ur 60 bux at end of year for you is way different than mine
calgecko
Sacramento, CA
www.instagram.com
*Willing to spend $40-$50k on a vehicle
87 octane currently is $3.39/gallon near me and 91 is $3.69 -
*Not willing to spend an extra $4-$5 per tank on good gas
Makes perfect sense :rolleyes:
andi
Lol exactly wat I’m saying
