Sadly a pretty common problem. I for one wouldn't pay to get them replaced and would raise heck till Ford payed for it.I thought I would warn some folks in case they want to do this. Please don't do what I did.
About 7 months back, I removed all five beauty rings from my 2Dr Badlands (33" Optional Wheels).
I took them off to plastidip the rings to see what the color would look like if they were straight black, which I ended up loving.
The problem was the damn bolts were awful to remove. Several were horribly cross-threaded. Just don't remove them. I stripped two screws, and two of them were "supposedly" not screwed in correctly onto one of the wheels when I re-installed the beauty rings (even though I had the proper bit/torque wrench, etc. (and Ford won't fix them under warranty).
The dealer needs 18 new screws and a NEW WHEEL to fix it for a whopping $3500! Which I laughed at. Anyways, I wanted to get new wheels one day, so - I guess that day is today - but don't mess with them. I still feel the threads were done poorly by the manufacturer, which shouldn't fall on the customer to replace. Removing beauty rings should not be something this challenging for any consumer. But because I pastidipped them and did it myself, I am at fault. Even though several of the bolts were obviously cross-threaded, and poorly constructed.
Anyways, save yourself the trouble. Don't remove them. I'm keeping mine as is, missing a screw, etc. But that was a painful lesson to learn. I'm still calling Ford to raise hell on the threading issue, but I doubt I will have much luck.
