Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Thanks for the list!
The OP needs to list the REAL steering fix !!! Not the list of band aids available....
Here it is folks the HOSS 3.0 Steering Ford Performance steering rack and HD tie rods. And here's the part number for the complete kit. Mine is getting installed tomorrow morning.
NB3Z*3504*M
Looking forward to hearing some details from those that go this route.
Is it an option for all trims and packages, or only certain ones?
And what exactly is the difference between the 3.0 tie rods and stocks?
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Gen2 Raptor Midtravel / TowRunner F250
the Hoss 3.0 package is only available on the wildrtrack as an option.
the tie rods are 30% stronger and the rack is the same one from the bronco R. The hoss 3.0 also gets fox 2,5 piggy back resi shocks @Natai
Natai
Sean
Sacramento
I know the 3.0 package is only available for WT, but he posted the part number for the steering rack and tie rods, so I'm wondering if those parts can be installed easily on other trims.
What is it about the tie rods that makes them stronger? Different materials, different design, what?
DoYouBronco
Tyson
El Paso
hpbuilt.shop
I believe they are a thicker diameter, and yes I don't see a reason why the the rack can't be installed on any of the trims.
  • Like
Reactions: Cat
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
NB3Z*3504*M
Was yours $950ish from Ford OEM parts? I’d like to see a picture of what’s included once you get yours.
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
NB3Z*3504*M
Is this being installed by a dealer so they flash the correct settings for the rack? Are you gonna do a write up?
j_marinelli
Spring Branch, TX.
66Fan
Tim
IL
2022 Wildtrak
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
NB3Z*3504*M
I can’t consider this a real fix until ford makes the software available to make it plug and play right now it is not and a dealer will not do the swap. Awaiting Bigmeats outcome to see if it’s a success with dealer support or at least works.
Theherofails
Thomas
Phoenix
Must have mod if you off-road. The inner tie rods are cheese. Carry a spare as well.
I did some high speed stuff with some mild jumps with the JKS and the tie rods survived just fine.
mC.242
2021 Big Bend 4dr (sold)
JKS Sleeves here, no issues.
However, the Kid chaos splint looks to not be a bad idea for the price either.
I have these sitting on my desk waiting to install. How difficult was it, and did you have your steering re-aligned after?
Busterbronco1
Andy
2005 Mustang GT Premium and 1982 F100 Short Bed.
I got the RC braces. I figure when I put the lift / leveling kit on there, I will have to do an alignment anyway. Besides, when you take off the tie rod ends, just count how many turns carefully to remove and then put that many turns back in. It should be relatively easy .
