What genius at Ford?
BroncoKing610
NJ
2021 2.7L Bronco
Who the F### at Ford design the rear of the Bronco to make it f%%%%ng useless for towing unless you remove the spare tire every time
*I have factory tow package
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
No problem towing here
OP what issue are you having?
BroncoKing610
BroncoKing610
NJ
2021 2.7L Bronco
Idk what you are pulling but every boat trailer Ive towed with my Bronco has required taking off the tire so the safety pin doesnt hit the tire/bottom of tailgate
A51Bronco
Geoffrey
Texarkana
2012 Ford FX4, 2022 Bronco Wildtrak
Maybe you just need a ball with a little more drop? I've never had a problem pulling a trailer with it.
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
I've pulled my teardrop trailer and also my quad trailer since day 1 with no issues,well only issue is can't open rear door when pulling trailer because they thought copying Jeep would be smart instead of a drop down tailgate :mad:
604Bronco
British Columbia
www.bronco6g.com
No issues towing with mine - wish the tow capacity was higher, but it’s been great for my uses so far.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I've had to remove the spare to tow a small camper with an electric jack that was in the way. I also had to remove it to tow a U-haul 6x12 enclosed trailer. Did not have to remove to tow an open motorcycle trailer from Uhaul.
What gets me is the location of the wiring - I've had to remove the wiring bracket to get my bike rack threaded pin in.
cbrenthus
Western PA
And remember that extended and drop hitches add leverage and lower your towing capacity ;) Someone on here awhile back actually came into a thread about that with facts and math to show how much.
BroncoKing610
BroncoKing610
NJ
2021 2.7L Bronco
I use the standard hitch with the common 2” drop…I would need at least a 4” drop to be fine but at that point the trailers will be pointing down which is a no no
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
which way does the tongue go where the ball is attached. Is it swooping up or down? If up, then flip the ball over to the other side.
