Which 40 or 50 inch light bars are you planning or using?
Gtrekker
Gary
NJ
What size light bars are you planning on using? The 40 or 50 inch light bar? Thanks.
Rigid 40" curved with BG brackets and a diffuser.
Ford Bronco Which 40 or 50 inch light bars are you planning or using? 20220517_173244
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
How are y'all powering the light bars?
AUX-1 switch has a max of 30A, but the wiring from the front roof location is pretty thin, and I'm not sure it's enough to handle the draw.
Has anyone experienced any issues?
Virgil
Ohio
BMWs-M5 & 750; Dodge Charger SRT, 30 4WD pickups
Have the 50" KC Pro6 LED light bar sitting in my basement waiting on my Bronco. I'll be using BAMF brackets.
And the warrantee on the lights will pass before you get the Bronco!
Shodan01
Greenville, SC
2022 Bronco WildTrak
Following this as well - interested to see input.
mikeeshim
Los Angeles, CA
I ended up swapping the oem AUX switches to a SwitchPros 9100 with a mount printed by SDHQ.
Plenty of power and options, and replaced the oem wiring with heavy gauge wiring.
Ford Bronco Which 40 or 50 inch light bars are you planning or using? PhotoGrid_Plus_1654973777025
Ford Bronco Which 40 or 50 inch light bars are you planning or using? KakaoTalk_20220620_065343096
JediMcMuffin
Tommy
2021 Bronco Badlands
Looks good! Exactly which wiring did you swap? The leads from the fusebox? I had understood that the switches themselves didn't carry any current.
mikeeshim
Los Angeles, CA
Ford Bronco Which 40 or 50 inch light bars are you planning or using? diagram-1-aux-circuit-setup-v3-1
The presupplied wiring from the roofline through the A-pillar was swapped, and the wiring from the front grill to the fusebox was swapped.
By saying swapped, I actually mean that I didn't replace the wiring, but just used better wiring in it's place, as I left the OEM wiring there. Didn't want to risk having an electrical fire.
JediMcMuffin
Tommy
Oh I gotcha, yeah that makes sense, its a bummer they didn't run thicker wire to the roof top position. I also don't like that you have to give up one of the two power extensions to the glovebox. What if I want power in the glovebox AND in the rear, AND the rooftop?
Bird Dog Off Road
Jody
Chicago, IL
www.youtube.com
I used the 42" LasFit Auto lighting light bar with Quake LED brackets. Great quality for a great price.
mikeeshim
Los Angeles, CA
Ford Bronco Which 40 or 50 inch light bars are you planning or using? 285543638_3271476066441444_5749860058861393762_n
How's your wind noise with the light bar? Notice any changes?
I noticed mine will start whistling a tune between 81 mph up to 86 mph.
Since that's in my range of normal highway cruising speeds, it's getting a bit annoying on longer drives.
Until my Trailrax roof rack comes in with the wind deflector, I'll have to stay under 80 mph.
Bird Dog Off Road
Jody
Chicago, IL
www.youtube.com
TBH, it gets pretty noisy above 70 mph. I'm think about getting the rigid brackets (link in my Youtube video's description) that sit it lower to see if that helps. I may just take it off/on for long road trips.
mikeeshim
Los Angeles, CA
What kind of noise do you get?
Mine is a high pitched whistling noise.
