Which Aux switches for oracle grille letter lights and fog lights
marjen
CT
So I am picking up my bronco tomorrow. I purchased the oracle bronco letter lights and their fog lights for modular bumper. I want to use the six switches for the two lights. Does it matter which goes to which switch? Was going to use 1 for Letters and 2 for fogs but not sure if it matters.
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
All the power capabilities are in your manual or available via search feature here. Heavily covered repeatedly.
Dmorty217
Derek
Venice FL
Camery
Donā€™t use either 1 or 2 since those can handle the most amps from the factory and neither of those need that kind of draw. I have two led bars on aux 6 and my 4 ditch lights on aux 5. Again the first two (aux1&2) can handle up to 30 amps I believe it is
SavSqch
Savas
CT
2022 Wildtrak
Mine are on switch 5. Hope it helps.
marjen
marjen
CT
ok thank you for the response. I will look to use 3 and 4 then. Also ready through another post to look into maybe adding factory fog button? And looks like someone might have a pigtail if i have the wiring in the bumper. I a. Getting mod bumper so will check it this week.
marjen
marjen
CT
antman92
Toronto
Edge
mine are switch 6
  • Like
Reactions: cve
Fordmanbob
Bob
KS
2018 F150 4x4 supercrew, 2006 F350 4x4 superc.
I put mine on the purple wire#4 switch
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
Mine are on #6. Hope one day to get them on the DRL circuit.
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
I'm running my ditch/fog lights on #6 and my ARB air compressor on #5.
ā€˜21OBX
90Bronco19
2022 bronco outer banks
I believe 4x4 led (sponsor on here) has the pig tails I bought that plug right into the factory fog light harness. Cheap to I think around $20 for a set.
marjen
marjen
CT
i did see that. I have a 2 door big bend with mid package so I donā€™t know if it has the factory wire. Will find out today.
marjen
marjen
CT
i guess the reason I originally asked is I did not know how much power the lights needed. The oracle fogs come with a 30a fuse so figured they needed to go on aux 1.
helifino16
Ron
Mount Sinai, NY (Long Island)
Put mine on Switch 5. I just leave it on all the time. I really like the look and have gotten many compliments.
Ford Bronco Which Aux switches for oracle grille letter lights and fog lights Grill Lights1
