window getting caught when opening door
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
Same issue. Dealer first said it wasn’t covered because I had window tint applied but have since changed their tune. No resolution yet, opened ticket.
Frankie945
Frank
Louisville KY
Q50
Yea the window thing sucks and I don’t see a fix for it either unless ford uses better motors that are faster. You’d think the testers that had the Bronco’s on the road would of said something. That would of been one of my first complaints. Most of us caught on to it from day one.
HideoutBronco
Hideout, UT
1994 Land Rover Defender / 1985 Porsche 911
You can’t just open the door. You need to pop it open give it a second and the window will come down.
Terrible design. Every other car I have owned with frameless windows was quick enough I didn’t have to wait.
jasonf
jason
california
f150
Does anyone have this problem on a Bronco with the High Package or Lux Package?
yes i have this problem on first edition - i reset it but does not stay long always returns wacky
Monster1926
GMC Sierra 2500HD
It’s finally starting to get cold and snowing here in Indiana and I’ve been noticing icing issues. I can totally see a window freezing up and breaking when someone opens it.
TX-Hans
These windows are going to be in an issue. Already seen two broken ones, both rear passenger which happens to be the worst on my Bronco.
Ford Bronco window getting caught when opening door E924DDA3-B478-42A8-98E6-48C086B4088F
Sorry to see that happen to you. Our rear passenger side if the 1 of 4 that hangs just too long when opening that it catches. The other 3 work just fine. I have seen others mention the rear passenger one as being the problem child. Not sure why that would be a common issue...bad electrical design to that side of car that results in a voltage drop causing slow response on the window motor?????
Last Ride Bronco
southern USA
Nissan pup
The 2 door windows are more likely to break because of the large expanse of glass. The larger the frameless glass, the more unstable.
Swynn106
Madison Mississippi
1968 Bronco and soon to be 2021 Outer Banks
My 4 door is at the dealership right now because of the rear passenger hanging up. I get scared every time I open it.
Ksjrb03
Tx
F250
Same here, I actually don't let anyone open that door anymore. I haven't had time to take it in, let us know what they do!
Mr. Nice
Jayson
Minnesota
12' Boss302, 08' Audi TT, 13' CRV, 14" Ridgeline
Car and Driver July 2021
“Also, when someone tugs a door handle, the indexing glass doesn't drop quickly enough and often snags on the weatherstripping.”
They said a lot of bad things. You just have to read them.
The 2.3’s brakes were another. This is a vehicle of many comprises but most everyone likes them.
Lucas
Dallas - Fort Worth
My passenger front door was pretty bad. Dealership did something to fix it. Now I just wish I'd had them do all windows 🙄
CarreraX
Centerville Ohio
E30 M3, 993 C4S, GTI
My 2 door does this and its unacceptable. Ive had other cars with windows like this (E36 M3, 996 etc) and they worked flawlessly. Im going to try the reset thing when I get home. Does anyone have a 2 door without this problem? Thanks in advance!
