2021 Sasquatch Bilstein shock leaking and Now (6/28/2022) a broken CV joint at the transfer case
Bwaggs83
Brandon
United States
VW atlas
Update: I took Bronco over to the dealership today(6/28/2022) and I told them about some humming at higher speeds. They said I have a broken CV joint at the transfer case. They are now ordering me a new shock and new CV joint. I had my rear output shaft seal at the transfer case replaced prior to this. Interesting to say the least
Well 13K miles in and my front passenger shock is leaking all over my axle. It puddled up in my front lower arm skid plate as well. Looks like it's coming from the top of the shock. Should be covered under warranty. Wanted to keep everyone aware of these things failing.
Ford Bronco 2021 Sasquatch Bilstein shock leaking and Now (6/28/2022) a broken CV joint at the transfer case 1656086728504
Ford Bronco 2021 Sasquatch Bilstein shock leaking and Now (6/28/2022) a broken CV joint at the transfer case 2871E5EB-B063-4CFB-BDF9-F3504121BF33_1_105_c
Ford Bronco 2021 Sasquatch Bilstein shock leaking and Now (6/28/2022) a broken CV joint at the transfer case 631E556B-3159-4DAC-B444-DE4A01DCD05B_1_105_c
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
View attachment 345056 View attachment 345053 View attachment 345055
Hi there. This leaking concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
Bwaggs83
Bwaggs83
Brandon
United States
VW atlas
Updated thread!
ryartz
Rick
Ford F150
Sent my 23 Bronco with 5000k miles in to the dealer today to check a front coil shock leak. The dealer service center said it was normal leakage. It’s leaking enough to get oil on the frame rail.. Not sure I agree.
