Just asking for a friend: anyone burn a clutch off roading hilly rock trails in their 6G manual trans yet? If yes how did that end up?
so crawler gear and giving it gas in 4 high could maybe burn it?Won't lie, I will be impressed if he burned that clutch out.
The gearing on the Bronco is so low—especially with the crawler gear—you can usually just let go of the clutch and it'll be perfectly fine. Even while off-road. It's almost like you have to actively try to burn the clutch up.
BUT, it he wasn't in the proper gear or he didn't shift to 4-Low... yeah... I guess I could see it happening.
If you are sitting there giving it gas while riding the clutch (regardless of gear)... then yeah... you can burn it up for sure. That's how you burn up clutches.so crawler gear and giving it gas in 4 high could maybe burn it?
Hopefully it doesn't turn out like this...I can literally walk faster than the Bronco moves when in Crawler & 4-Low.
Haha.Hopefully it doesn't turn out like this...
wasn't VW's version of the hill-holder working on the sportwagen?I don’t have my Bronco yet, but I did have some trouble recently in my wife’s manual VW Sportwagen.
I had to come to a full stop on an extremely steep paved street in Virginia City NV. I tried three times to get going but stalled without making any forward progress each time, even with high revs and clutch slipping. I had to back down in shame.
Thangs that made it impossible:
The small, low compression turbo engine
Tall first gear
Altitude
Weight of 4 passengers and stuff in the back
I later suspected that I might have been able to do it without traction control. A little bit of wheel spin would have been better than clamping the brakes.
I imagine that the crawl gear in the Bronco would make it easy.
Yes, the hill holder works. It didn’t roll back but stalled before making forward progress.wasn't VW's version of the hill-holder working on the sportwagen?
more than likely, the clutch is worn enough to require replacement
Commenting for a friend… it’s a VERY bad smell. It’s also shifting fine but really keeps you wondering about to longevity of itI just had an incident where I should have been in 4L and definitely smelled some clutch burn. I wasn’t able to get out of 4H in time and had to do what I had to do. It’s shifting fine and I got out of the rut I was in…but, hoping there’s no lasting damage. Similar happened on my steep driveway once. I was in 2H and should have been in 4H. Got me right up once I switched. But, that was the first time I smelled it…I probably should avoid these instances
