Why do you use a long handle breaker bar, or slip a pipe over the handle to lengthen it even more to loosen stubborn bolts?
Well, that handle is the tire radius and the stubborn nut is the axle tube when using TTA.
Bigger tire diameter, means bigger radius, means more force applied to the center for the same amount of friction/traction on the tire tread (outside).
As explained in this thread, I read the break is fixed to the axle tube. Now, instead of breaking an axle (common when going to large tires), if the break has enough clamping friction to keep the tire from rotating, all the force is directed to the axle tube.
I don't know exactly how all that pans out, but this is my explanation of the simplified physics model people are referring to. It has nothing to do with engine torque. You can do the same by towing a dead vehicle with 1 rear break locked. And I think the Bronco has open diffs, so all engine torque would be directed to the wheel with least resistance; the outside tire in the case of TTA.
I would think you'd need an awful lot of friction between the tire and ground to break the plug welds, but that is a complete guess on my part. I do know as you move up tire diameter you need less traction to apply the same breaking force to the axle or, the point of this thread, the axle housing.
