cynicalrider
NJ
First gen taco
If I opted for a Wildtrak for the stronger rack, only to find out that I could've saved $10k by going with the Heritage Edition while not losing out on much other than some shocks..... I would've been disappointed after everything else that went on with the WT since the start.
IMO if you aren't looking at the 22.5+ Wildtrak for the suspension you are looking at the wrong model. Granted I came into even being actually interested and ready to buy weeks before the 3/27/23 order dates so I can imagine those who went WT without the HOSS 3.0 suspension is sorely disappointed. I really wanted the wash out floors just because the wheeling I do is very wet sandy but I figured getting something properly setup suspension wise was more valuable to me because this truck is supposed to my truck that "just works" and my other rig is the constant ever evolving project. That said those who do get the WT for the suspension should be very happy and impressed with the performance. I know I am.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Just now realizing these were the Ford (and AHEM Bronco Nation) folks who were at the Offroad Connect in Amarillo a few months back.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Anyone hear if someone broke the 3.0 rack and tie rods besides BroncBuster on 40s?
AFAIK the only ones to post here have been a couple of the more "hardcore" Braptor owners who have damaged their OE rack (which is virtually the same as Hoss 3.0 w/raptor tie rods). Those were the 1st ones to do the 74Weld. I have yet to hear of a Hoss 3.0 swap into a non-raptor that has failed...and I follow that thread pretty closely.
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
My 2023 Black Diamond (AdvancedTrac), 2.7, Mid Pkg, soft top, 4 door just finished production this week.
I have already declined it and ordered a 2024 Big Bend Sasquatch w/mid, bumper, aux switches, and signature lights.
My 2023 Black Diamond price = 49,822
My 2024 Big Bend Sasquatch price = 53,024
For just a bit over $3k - I lost the 2.7 (sucks) and rock rails, but gained: 12" screen, SAS (H.O.S.S. 3.0 steering), signature lights, and mod front bumper.
I definitely won in this case. might be one of the few.
RagnarKon
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Are hoss 2.0 broncos able to upgrade to the hoss 3.0 tie rods only or do you have to have the upgraded steering rack too?
I believe so... maybe?... but even if you cannot, there is a lot of aftermarket options.
My personal opinion: You may not want to do that. I just have a set of spare tie-rods that I carry in the Bronco when I'm doing any rock-crawling.
Tie-rods are basically the "fuses" in the steering system. They are designed to break before the steering rack itself breaks, much like a fuse is designed to blow before the electronics behind the fuse are impacted. So if you reinforce the tie-rods, you may just be moving the weak link to the steering rack itself. And obviously the steering rack is a lot more expensive to replace than the tie rods. Not saying that you shouldn't replace the tie-rods, but just be aware of the potential downsides.
I saw a Wildtrak owner with broken tie rods being towed out of a trail by his buddy's Black Diamond. But... it was pretty clear he lifted his Wildtrak because that thing was gigantic compared to the Black Diamond. And I don't know if he bothered to correct or account for the geometry changes after lifting it.
I certainly haven't seen a factory HOSS 3.0 Wildtrak with broken tie rods.
Boostedblues
Joe
Kentucky
2016 Focus RS, 2011 F-250, 2004 Ranger 2016 Fusion
That's what I was thinking as well. i think it mainly happens to lifted/ modified rigs. not to mention lack of experience and speed can cause damage while crawling.
Bmadda
Wisconsin USA
I can confirm yes! They do fit. Use hoss 2.0 boots/bellows...whatever you wana call them, and maybe a heat gun just to warm the small end a tiny bit, and they will stretch over the Hoss 3.0 inners. If ordering tie rods only you will need 2x M14x1.5 nuts for jamb nuts...not included w/the tie rods
Bmadda
Wisconsin USA
21 and early 22 WT didn't have Hoss 3.0. 22.5 it was only optional...did you happen to see if it was a Hoss 3? Or just noticed it was a WT?
Boostedblues
Joe
Kentucky
Awesom! thank you!
NightShade
Cumming, GA
2012 F150, 2023 Wildtrak
Hoss 3.0 on all Sas Bronco's, another kick in the nuts for the Wildtrak guys.
👆🏽Essentially giving away the main differentiators from WT to BL. What would be the point of paying more for a WT when you have zero compromises with a BL now? Might as well phase that model out. Good job Ford!
Thanks for the transcript RK
NightShade
Cumming, GA
Sure but it’s waaaaay worse for EVERY Badlands owner with SAS (so pretty much all of them). Their resale is OVA
Then either kill the WT or come up with another big differentiator to justify its price point, ie. 3.5l motor and better towing.
Bmadda
Wisconsin USA
It's just the steering...NOT the whole Hoss 3.0 package. WT still is the only trim that gets the "cool duder" coilovers
NJNMDoc
Southwest
Bronco Wildtrak
Oh I agree- I think they’ll kill the WT. The primary difference as of MY’24 is the Fox Shocks and they are great but that’s not a model line differential.
And while that sucks, it doesn’t suck nearly as bad as having a Badlands SAS with a plastic steering rack, #2 pencil tie rods, and some off-the-shelf bilstein shocks. Those folks are waaay over a barrel if I can buy a MY’24 BB SAS with better kit.
NightShade
Cumming, GA
WT owners weren’t paying premiums for cool dude coil overs. The majority advantages of having a WT have essentially been given away to level off the other models. There is nothing for ‘24 WT that would warrant stepping up to what is the largest price increase for the lineup. Based on this logic, they may as well kill the WT.
