Dent in my MIC hardtop!! Branch fell onto my roof
Hoss360
Fairborn, OH
2021 Bronco 2 door
Honestly, I'd just fill with some bondo and sand it smooth... then make an appointment to get the hard top Line-X'd
Looks better, and will be more durable long-term. I had mine done, and it makes a huge difference in the overall look
2023bronco
usofa
2023bronco
Ford Bronco Dent in my MIC hardtop!! Branch fell onto my roof 20230511_184040
How does that stuff hold up against UV? No fade? Seems like a good idea for the OP. Or prep and paint whatever color and sheen he wants.
Taco2Bronco
JP
Tacoma
How much heavier are the panels after the LineX?
Hoss360
Fairborn, OH
2021 Bronco 2 door
I've only had it for 3 or 4 months. No issues yet, but don't really expect any fading, as this is bedliner. Resists scratches and tough as can be.
I'm sure it weighs a bit more, but not noticeable. Still easy enough to take the front panels off, and still a 2 person job to remove the rear portion.
Only downside is a bit more wind noise due to the texture. But looks good enough to ignore a little extra noise.
Rick Astley
Up Doug's ass
d
If you do claim it through insurance, i would strongly consider the new abv hard top (i think its abv, whatever the hardtop is that just came out with the slightly slanted back). Regarding filling it yourself. It’s possible but i can’t imagine it being a water tight seal. And as you can tell the factory hard tops are basically cardboard on the inside. Once water gets in, thats it. Mold mold city.
Yea, fiberglass is essentially the bulletproof material which served so many so well for so long....
It's strange how you don't see too many of these cherry body kits anymore, why is that?
Oh right, Pepperidge Farm remembers.... It's because they crack like crazy and are ridiculously time consuming and expensive to repair. Sadly, Ford chose a roof construction which is only one small step more durable and robust than fiberglass. It's not much, but it's something, fiberglass is not an "upgrade" material.
omi205
BoJack
Austin
It might not be the golden bullet but it's also not going to separate and crack on its own nor will it puncture like a balloon. Nor is it filled with cardboard (literally). I mean, all that to talk simply to trash a possible solution...without providing a solution. Thanks man. Really. Wonderful contribution. LOL. Common dude.
Im just going to put this right here....ahem ahem
https://www.bronco6g.com/forum/threads/adv-vs-oem-hardtop-comparison.74982/
Rick Astley
Up Doug's ass
d
At this time there isn't a solution to "why are these roofs made with terrible materials?"...
If there was the answer of "company X makes one out of stamped aluminum" then I would have been singing that from the trees.
As for the OP, I would personally fill the compromised roof with silicone or resin. Something hydrophobic yet flexible. However, I would look into any warranty/insurance solutions first, as you don't want to be denied by trying to fix it. Once the bean counters have the paperwork in order then fill it and wait for the eventual outcome.
^^^ Was that better for you, @omi205 ? It seemed like the level of common sense that, apparently, needed saying to placate you.
omi205
BoJack
Austin
You sure your ok man? Someone take something from you today?
Let me get this straight. You think that "warranty" still applies here. :ROFLMAO:. Yah OP. Take this to your local ford dealer and try to make a claim under "warranty". Can't wait to see how that goes. "a tree fell on hard top and put a hole in it, clearly manufacturing defect, can I have new one?" :ROFLMAO:
Regarding your comment on fiberglass being "bad". Every Wrangler hardtop is made of...drum role...fiberglasssssss. How many issues do you see with them? Have you owned a Wrangler @Rick Astley? Guess what. I have. No issues at all. Im also part of the wrangler forums. And guess what. No threads on their hardtops going bad either. Claiming that the Ford Bronco MIC hard top is superior to a wrangler fiberglass hard top (or fiberglass in general) is misleading. The ABV hardtop is most definitely superior. You not liking it, is your own opinion, for whatever reason.
Rick Astley
Up Doug's ass
d
You win the internet! You guessed it, I only work on 2-stroke unicycles and the only forum i've ever been on is this one. Nicely done! Where do I get red shackles for my front bumper, and you've changed the world, fiberglass is the indestructible roof material of the gods! (PS: don't look at this, apparently fiberglass on wranglers can crack as well. https://www.wranglerforum.com/threads/cracked-2021-jl-hardtop.2441903/)
FWIW: I didn't bring wranglers into this (you did), and I didn't bring your other forums into this (again, you did. I think to add some sort of extra anecdotal validity?). You want accuracy in your quotes., be the change you want to see in the world.
Strangely, I did answer @erics667 actual question regarding filling. Perhaps..... FILL IT WITH A WRANGLER, AND READ ALL ABOUT IT ON THE JEEP FORUM!
GroovyGeek
Boyan
'23 Bronco BD
Why would't bondo work? It is routinely used to repair dents. Sure you have to sand it and paint it, but that patch is on top of the MIC where noone would ever see it.
Editorial comment: Ford really shit all over themselves with both the MIC and the soft top. One is made of fragile egg cartons, the other looks like a saggy POS on every photo I have seen. "Hidden" snap buckles hold the windows in place? Really @Ford Motor Company? You couldn't contract with @Bestop_Team and let their decades of experience help you get a better soft top out?
omi205
BoJack
Austin
I am so confused. You came swinging at me from left field, with your initial comment, and now you want to play victim. You literally attacked my comment suggesting that OP explore AVB as a possible alternative. If you read a bit more, I also suggest to OP possible insurance and possible repair. Stop man. Why are you turning a place of sharing ideas into a hostile place. Why?
The only reason I brought up the Wrangler was to point out that fiberglass (your worst enemy, apparently) is working extremely well for them, for years...but for some reason you hate it. Thats your personal opinion.
HeliPilot
Kenny
CT
2022 2.7L SAS
If it were mine, I’d stop by a boat repair facility. They repair boats that have run into docks daily. They should have the ability, or know the shop that does. May even be cheaper than an insurance deductible.
