Everyone needs to let him know these will sell - 6.5" Speaker pods for the rear
Strykerwsu
Wichita
Holden Commodores
Did you have to update anything in Forscan for the B&O system? Or just swap out the rears?
No updates just swap. I believe this was discovered a whole ago in Forscan thread that B&O has range but 4 inches just don't have enough umps to matter.
TXBrian
Dallas
2022 Bronco
I thought there was one line that needed to be changed in forscan to get full range to the rear ?
Johnny Mo
Westchester County, NY
teachu2shoot.com
Ford Fusion Energi, Ducati XDiavel
Those are nice, but I'm leaning towards a set of wake tower speakers if I decide to upgrade my B&O rears.
Trickster
Trick
Tucson, AZ
22’ Badsquatch, Lux, Cactus Gray, 1991 5.7 bronco
Not for B&O. For base yes.
So your saying if you have B&O system, changing parameters in Forscan won’t make a difference at all? I went with some pretty expensive 6.5 hertz paired with alpine 180 amp and they def sound better but there is some room for improvement, it’s like they have a governor on them or filter holding the full sound back, they sound really strange in surround mode
Strykerwsu
Wichita
Holden Commodores
I'm just gong but what I read in the Forscan thread and the JL Audio 6.5 speakers installed that are providing full frequency. I was surprised how much better the sound is compared to prior 4 inch. Finishing touch for me to be happy with sound overall.
If you added an amp aren't you already bypassing the B&O?
Trickster
Trick
Tucson, AZ
Thank you, no, I don’t think I’m bypassing the factory DSP as my Alpine does not have a built-in DSP like I think the kicker keys do, so I think I’m just accentuating the existing factory DSP limitation’s going to those pods. I do have a kicker 200 on my front stage and I also have the 500 on my DVC sub which I’m very happy with. Just trying to clean up those rear pods, I have been trying to make sense of what MOBRONCO https://www.bronco6g.com/forum/members/2932/ has been saying and not sure if forscan changes are going to provide any better fuller signal to those pods on my B&O system (which is funny since the only thing that’s left from B&O system is the DSP at this point)
Strykerwsu
Wichita
Holden Commodores
You are definitely more advanced on your upgrade them me. I didn't try to figure out how to try and add power to the current system. So I could very well be incorrect, but just going by what I had read and am hearing. I will try to quickly find the thread notes which stated full range on B&O tonight.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
I'm going to try the pods........w/ 6.5 Kicker KS - I already have a Kicker Key 200.4. I have no sub and I'm actually happy with the bass. But im sure with this addition it will be even better, especially after the forscan settings are done.
Soooo........Where is the link to buy these??? I can't find them on Amazon.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Here is the link.....but currently out of stock: Amazon.com: Mabett Rear Speaker Pods Compatible with Ford Bronco 2021 2022 2023, Upgrade 6.5" Pods for Bronco Accessories 2/4-Door, Interior Accessories Black : Automotive
Trickster
Trick
Tucson, AZ
You’re gonna love them once you get your hands on them, I sound matted the interior of mine. Please report back once you do the Forscan update I’ve heard two different opinions on whether or not it really makes a difference.
Ford Bronco Everyone needs to let him know these will sell - 6.5" Speaker pods for the rear 5E051891-8C9D-4C5F-8D45-76A11995A97A
Strykerwsu
Wichita
Holden Commodores
This is the thread I was reading. One of the posters with a lot of speaker upgrades tested and stated had full range. There is another note that sounds like B&O with sour bar does have a forescan code you can change to see if improves.
https://www.bronco6g.com/forum/threads/full-range-to-rear-speakers.35116/page-24
RowsKing
JR
SJ
22 BRaptor, 66 Stang
Does anyone know if these speaker pods would fit in the Raptor? Will the xtra cross brace in the rear be in the way?
TXBrian
Dallas
2022 Bronco
So you just wired in amps to the factory B&O without using any of the adapters for dsp (zen nav, access, etc)?
Trickster
Trick
Tucson, AZ
that is correct for all three amps, just cut into factory speaker wire and use as your line in feed
