Flat tow equipment needed to flat tow the 2021 Bronco?
kylesredapple
kylesredapple
Kyle
Gallup NM
77 F150 4x4 SB, 16 f150, 15 powerstroke,94 Honda A
Depends on the brake system you choice. Some require the power brake to be active when towing and some do not. With vacuum boost the system will include a vacuum pump to supply the vacuum when the engine is not running. Electric brake boost is kinda new and must be know when buying a brake system. All electric cars have it.
Thanks. I did not use any brake assist system with the liberty and my f350 didn't notice it was back there but I'm quite certain the Bronco will be a different story. thanks for the insight its much appreciated.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Tow Bar safety cable connection points. Finished installing the eye hooks this morning. Not plug and play as I though. Nuts on the bolts holding the front crash bar are welded to the frame. So had to remove and drill them out to 1/2". Added a bit of rubber hose to the edge of the bash plate to keep from rubbing the edge.
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? Nut before
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? nut after cut
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? Hooked front 1
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? Hooked front 2
dgorsett
colorado
F250, Mustang, Explorer
Ok I have the 2.3L Manual. so it has a vacuum boost. Does this mean I will need a specific brake boost kit?
As grtharris says, it depends on your auxiliary brake system. I use the RVI and it actually uses no boost and works well with vacuum because you cycle it three times at set up to bleed off vacuum. Bottom line: research what type of aux braking you're considering and be sure it's compatible with your Bronco.
dgorsett
colorado
I used to tow without an aux brake. I noticed myself pushing yellow lights to avoid quick stops. So aside from legalities, it made me do stupid stuff. The couple times I've had to stop quick now with the brake make me realize how important it is.
grtharris
Grant
Skiatook, OK
OK, some info on installing the Blue OX BX8848 Tail Light Wiring Kit, Diode. Two pictures and two documents that helped a bunch. One is instructions on removing the tail light assembly and the other is the wire color code.
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? Left Side
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? Right Side
yourbudjim
2021 Bronco Badlands Soft-top High Package
Without precise measuring tool, I’m pretty confident the mod bumper shackle mount hole measures 15/16”. i did read towmasters description and the play when mounted Is probably totally fine to run. My mind just wants it to be solId and trouble free, lol. If that makes sense. I have to say this thread is refreshing. Rest of this forum is quite toxic lately
I received my
I received my 035-1 adapters the other day and everything you've been saying now makes total sense. I took them, along with my Badlands, to a local machine shop to ask their opinion on what I should do:
1) drill the shackle mount holes to 1" to match the included bushing
2) try and find an even thinner bushing to match the roughly 15/16 hole on the shackle mount
3) just run the adapters with the 7/8 pin and a little slop
The guy said he has a ton of experience towing heavy vehicles and the play using the 7/8 pin is absolutely not a problem. So, I'm going with option 3 and will let you know once I get all the bits together. Thank you very much for coming up with this! It really seems like the least painful option out there for a mod bumper.
grtharris
Grant
Skiatook, OK
yourbudjim sounds like a great plan.
Will pickup my Blue Ox adapters from the machine shop tomorrow and hopefully have my Bronco back from the paint shop on Thursday. Will send pictures after I put it all together.
Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
Of all the stuff on B6G, this thread is one of the best. Appreciate you guys blazing the trail and sharing what works. We just got our first RV this summer and want to set it up for flat towing the Bronco when it comes in. I will probably do exactly whatever you guys come up with
Dusty
Mentone, CA
70, 71 & '21 Broncos
Great information, thanks for sharing it! I've been flat towing my Bronco with drag lights because I've been hesitant to start cutting into the harness to install the diode kit. This info is helpful as I decide whether to continue holding out for a plug-and-play umbilical kit from Ford or other aftermarket company, or bite the bullet and install one of these universal kits.
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? IMG_0445.JPG
grtharris
Grant
Skiatook, OK
Blue Ox tow bar setup. Opened the BX88357 adapters up to 1.18" which gives a good 1/32" clearness on each side. I have new up arrow decals coming, got messed in the mill clamp
kylesredapple
kylesredapple
Kyle
Gallup NM
That looks so clean! Fantastic really! My bronco is on the train to my dealer. I can't wait to do this. I don't have your bumper tho. mine is the stock one.
kylesredapple
kylesredapple
Kyle
Gallup NM
So I watched @Dusty YouTube videos on his very clever fabrication for the adapters in the basic bumper. I think I'm going to do almost the exact same thing for the adaptors and then use the Blue Ox that you pictured. Dusty actually gave me a little inspiration for a bumper mod so I can put my winch on. Ill make a video and post my process like Dusty did once my Bronco is in my shop!
pstroke
Drew
Bluff Dale, Texas
20 Ranger FX2 CC, 21 MachE FE, 21 Bronco Sport
Now that Curt has an adapter for their tow bar on the modular bumper recovery points, feel much better about using the Roadmaster adapters.
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? 20211110_193413
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? 20211110_193423
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? 20211110_193430
Dusty
Mentone, CA
Save yourself some hassle and buy some of those tabs already made from @Oscargrouch323. His are similar to mine but better workmanship LOL. He sells them in This Thread.
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? 20211030_122827
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? 20211030_123555 (1)
