Flat Tow Wiring and Tow Hookup From the Factory?
Datoad
Fontana, California
06 Jeep LJ Rubicon, 17 Mustang
Likely a stretch, but when B&P is released with all the goodies that can be added to the Bronco from the factory, one really BIG item I want added is the lighting harness for flat towing behind an RV. The Jeep harness from (https://www.justforjeeps.com/jl-tow-vehicle-wiring-harness.html) cost $400+ and require instillation.
The big stretch would be to add the hitch receiver pins needed to hook up the tow bar in the B&P for the incoming flood of RVers who what to ditch the Jeep Wrangler for the Bronco - with a little hassle as possible.
Has anyone see any information about the lighting harness or interconnect for Bronco flat tow behind configurations?
I wouldn’t be surprised if the harness for the ranger would be the same but if not they will have one soon.
https://www.etrailer.com/Tow-Bar-Wiring/Ford/Ranger/2021/RM-154.html?VehicleID=202189499
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
BigIron
Merrill, Or
2002 F350, 2015 JKU, 2019 F150
I just run a 'flat 4' from front to back and use diodes to isolate the vehicle wiring, no big deal, get the 2>1 Diodes from roadmaster, a bit more expensive but high power and a snap to hook up.
Here is a complete kit that will work fine.
https://www.amazon.com/dp/B005HNYKE...colid=G5F9B9983RU7&psc=1&ref_=lv_ov_lig_dp_it
Yeah, anything can be Jerry rigged and spliced in. But, the Mopar harness is so nice and clean. plugs in directly to the factory harness with relays and will keep the battery of the jeep charged. It’s just so much cleaner I hope Ford will follow suit.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Looks we will have to use smart diodes to connect to the tail lights. Looking at the tail light wiring diagram looks like Ford is using variable voltage brake/tail light.
JesseS
Jesse
Northern California
In my world "Jerry Rigged' means something done sloppy, or half-assed. Running fresh cable, splicing in the diodes correctly, with soldered connections, waterproof heat shrink, and a little attention to detail is NOT Jerry Rigged. If Mopar or Ford offers a Plug-N-Play solution then great, but I am not holding my breath. And as I will need to tow it almost at once I won't have time to wait on Ford to get their act together. Oh, and the Roadmaster Invisobrake also keeps the tow vehicle battery charged.
JesseS
Jesse
Northern California
grtharris
Grant
Skiatook, OK
Any updates? For what it is worth the D-Ring brackets on the Modular bumper are 1.1145 thick. I don't have a problem opening up the BX88357 by .126" there is still lots of metal left. Just wish I could get a good answer from Ford about the D-Ring brackets . This is what the owns manual saids.
Note: Do not use recovery hooks to
recreationally tow your vehicle. See
Recreationally Towing Your Vehicle (page
307).
Well page 307 does not tell me anything. Are the D-Ring Brackets considered the same as the recovery hooks?
I did run across an article on flat towing the 2021 Bronco and he made the comment you could connect to the tow bar the the D-Ring brackets. Don't where he got his info.
dgorsett
colorado
F250, Mustang, Explorer
307).
Keep on this and keep posting!!
I'm considering replacing the tow 'loops' on a standard bumper with D-ring adapters and using those, but am as yet unsure. Hopefully Blue Ox, Roadmaster et al get on this soon. I was going to use my magnetic lights temporarily until something better appeals to me, but the aluminum body and plastic bumper will be problematic.
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
307).
If they are good enough to recover the vehicle when it’s stuck they should pleanty good enough to tow with.
what Dealer did you use?
grtharris
Grant
Skiatook, OK
Bill Knight Ford in Tulsa, OK. Got my window sticker, build date tomorrow!!!!!!!!!!!!!
grtharris
Grant
Skiatook, OK
OK when I saw these replies on my iphone there was one with a part diagram. But it is gone now.
dgorsett
colorado
Sooner
Ted
Henryetta, Ok
goatman
Richard
Bakersfield
A bunch of Jeeps
Roadmaster is looking for Bronco(s) to pattern a baseplate in Vancouver WA
FitMaster Product Match | Roadmaster Inc.
I'm about to order my Bronco. Guess by the time it gets here Roadmaster will have brackets ready. I'll move my tow stuff over from the Jeep. Also, looks like I can only get the 2.3L because it has vacuum booster brakes, while the 2.7 has electric boost. My Air Force One brake kit needs vacuum boost to work on the toad. I saw a video of it being installed on a new Ranger, assume it will be mostly the same on the Bronco.
dgorsett
colorado
Usually with electric boost you don't have to preset the system, with vacuum you need to cycle a few times to bleed off the system. I'd check with your brake mfg to be sure.
