For non powered subs, what amp are you using?
broncoToBe
Not a Bronco
Most people here rave about kicker 200.4, but that won't work for the sub. Recently ordered one of those stinger boxes, but I'm still lost on what to power it with
Dmorty217
Derek
Venice FL
Camery
Will depend on the sub and what it’s rated for. I have a kicker key 500.1 powering my sub
broncoToBe
Not a Bronco
Do you have a separate amp for the speakers? What made you decide on that vs a 5 channel amp for everything?
Cl1ckst3r
Joshua
Minneapolis
Ford Focus ST
JL Audio 12T3-D8 powered by Powerbass XL-2305MX which is installed in the storage area under the rear mat. This amp is IPX67 rated.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I am using a Kenwood https://www.crutchfield.com/p_113KACM3K4/Kenwood-KAC-M3004.html to power and 8" Polk slim sub and the 6" and 4" front speakers in parallel. Even running the amp in it highest power configuration, it has remained cool and trouble free. I also picked it because (product description from Kenwood)- The amp features a conformal coating on the circuit board to protect it from moisture. This allows you to use the amp for motorcycles, marine applications, or on All-Terrain Vehicles (ATVs). The KAC-M3004 delivers 50 watts RMS x 4 channels at 4 ohms. It also gives you 75 watts RMS x 4 at 2 ohms, or 150 watts RMS x 2 channels at 4 ohms bridged.
It wont survive a dunking, but it is mounted underneath the front passenger seat and will likely get an occasional drip of water or two.
MyBHinds
Kansas
1976 Bronco
JL Audio 600/1v2 and JL Audio HO112-W6v3 sub. Depending on how much bass you want. Hits very hard with top on. Sounds really good with top off but lose some of the SPL due to sound wave dispersion.
Dmorty217
Derek
Venice FL
Camery
I have the kicker key 200.4 in the dash for all the other speakers which were upgraded.
Indica
Alek
Illinois
‘21 Big Bend
200.4 for speakers and a 500.1 in back for my 12" downfiring sub. 48trtp122 kicker
marjen
CT
this. I use the kicker 500.1 to power 2 Audiofrog 12” drivers. Works great.
broncoToBe
Not a Bronco
Indica
Alek
Illinois
‘21 Big Bend
Did you guys use the plugnplay harnesses? I'm probably going this route, 200.4 for front, 500.1 for sub
Yes. He made me one harness that runs from the front all the way to the back.
Edit: I got kit 11-2 200.4 with harness, and also provided speakers. Called him to confirm/add to my invoice the 17 foot harness with load resistor for the 500.1 for an additional $45.
jcalifornia
Jeremy
2015 BMW 640i xDrive
Ford Bronco For non powered subs, what amp are you using? JL HO112 W6v3
Is this a 2 door or 4 door?
JFelty
Minnesota
Mustang Mach E
I paired a 10" Kicker CompR with a Kicker Key 500.1
Ford Bronco For non powered subs, what amp are you using? Bronco Sub
