- Feb 29, 2016
- 29
- 923
- 4,619
- Mentone, CA
- 70, 71 & '21 Broncos
- Base
I wonder if covering the entire back side of the hideaway sub enclosure with a single sheet of heavy duty velcro would be strong enough to hold it to the carpet on the seat-back? Isn't that how the seat-back liners from Mabett and others attach? Those are quite a bit lighter though, and not bouncing around everywhere when you're bumping some Eazy-EI used the straps and mounting hardware that came with the sub. The back of the seat is a hard surface, probably plastic, that is covered with carpet. I attached the straps to this using the screws that came with the sub. The sub rest on the ledge behind the back seat, so there's not much weight on the straps. If I ever want to take the sub out, all I have to do is unhood the two Velcro straps and unplug the wire connector.
