HELLWIG SWAY BAR test fit
1970Budster
Sara
San Dimas, Ca
2021 Ford Bronco 4 Door
Hellwig called me last week to test fit their new rear swaybar on my Bronco.
I have had their sway bars before on my Jeep Wrangler and I was really happy with it, and I honestly did know if it would make a huge difference in my Bronco.
When I first drove my Bronco I felt the difference and it felt super solid. Then I drove a the 241 toll rod and felt a huge difference on the handling.
THEN...I drove another Bronco that I have at my house right now, and it was a major difference.
All in All...I am SUPER Happy with my new addition to my Bronco.
Now I will see how it handles in Moab next week. :)
--My Bronco had the BAJA Kits suspension with the King Shocks and the other Bronco had the Icon Vehicle Dynamics Stage 7 kit.
--The Icon kit was way softer feeling on the road, but my Bronco feels way tighter and still rides awesome!
Ford Bronco HELLWIG SWAY BAR test fit Hellwigrearswaybar1
Ford Bronco HELLWIG SWAY BAR test fit hellwigrearswaybar2
Bikeric
Tulsa
2022 Badlands on 37's, 2003 V8 4Runner on 35's
Are they on the market yet, or are you the tester?
  • Like
Reactions: WOW
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
Definitely interested to hear the off road performance and if it limits you.
VE7 NGC
Nick
BC, Canada
22 Badlands Sasquatch
Some really interesting info for IFS vehicles and the interaction of swaybars front and rear in off road situations. This guy is using Toyotas as an example but it think this has some real crossover to our broncos. Helps explain the addition of the rear sway bar for 2022 on some models
orion
Jeremy
17' F-250, 17' Explorer
I can't wait for antirock to be available! I want to test out a rear only setup and see if it makes the front work more... keep it from 3 wheeling so much!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Do you know if Hellwig will be offering kits with mounts for those of us that don’t have them from factory?
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
I'm pretty sure that what was posted is supposed to be the retrofit. I just installed the version that replaces the stock sway bar using the OEM end links from Tom's Off-Road and those are not Ford sway bar end links. The sway bar looks to be very similar otherwise.
kingsingh14
Rohan
Birmingham, AL & Bowling Green, KY
2023 Ford Bronco BL SAS LUX 2.7
Have you noticed any difference with the upgraded rear swaybar?
CatMonkey
Lafayette LA
When you're really pushing it in a corner, the decrease in body roll is pretty apparent. I don't know that I notice a lot of difference at slower speeds. The factory bar is pretty dinky. Here's a pic I took of both side by side. The dip in the bar is under the differential, where the factory bar is above the differential. The bar is no lower than the pumpkin, however.
Ford Bronco HELLWIG SWAY BAR test fit Bronco sway bar
I'm only using the middle hole on the bar. It's probably not the hot ticket for the rock crawler crowd, but that's not my focus.
redone17
Cold Spring, NY
It's the brackets that are welded to the frame that I don't have. Early 21 build...
redone17
Cold Spring, NY
Off-road impressions?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Yeah, interested in that too. I find my Icons stiff enough to go without the swaybar for all my driving. Without the front swaybar I do get more articulation, but still have problems getting full up travel. The body rolls instead of the upside tire stuffing. I really like my rear articulation and don't want to lose that, but would like the weight distribution to be more level to allow the front to compress more.
redone17
Cold Spring, NY
Any indication if Rock Jock plans to offer brackets for theirs for those built pre-Nov 2021?
kodiakisland
Arkansas
They've not said any time I've talked to them. They did say they plan to have the finished version out this summer, but I don't know if that was only front or front and rear.
