HOSS 3.0 part numbers/cost?
Hedrock
Hedrock
Rome
4dr EG Black Diamond
@flip,
Are there any additional components that you can see needed for this swap? Like the spring perch and mounting plates pictured above?
My parts department didn't seem too knowledgeable when it came to swapping these parts. He did confirm the part numbers I brought in to him based on vin #'s were correct. The description for the struts says "shock absorber assembly", which I just assumed meant it was the complete assembly minus the spring.
some of them like 18132 and 5415 were additional ones he mentioned - it may have been the specific vin I provided, but he couldn’t even pull those parts or the equivalent for the front assembly, only the rear. Or maybe vice versa.
604Bronco
British Columbia
www.bronco6g.com
I reached out to my local dealership today and they mentioned the HOSS 3.0 system wasn't in their parts catalogue yet. They did say Ford is typically pretty slow on updating the catalogue, so I'm hoping they do soon.
flip
Phil
IN
www.ruxerparts.com
Fords
@flip,
The "assembly" is just the shock itself. I'd have to get a few HOSS VINs to look at HVBOMs to look up the front spring, insulator and other numbers. The catalogue shows the front two shocks but none of the other stuff yet. Cat shows the rear breakdown so you will still need the insulator, spring, top bushing, spring hat and retainer nut. The top retainer is a new number but works on all previous setups (when it first changed the only difference was the 3 studs changed from a coarse to fine thread). Spring is different as well as the rod insulator.
Get me a decent sample of HOSS 3.0 VINs and I'll update my suspension cookbook with those specific setups. To me, getting these new from the dealer would be very cost prohibitive considering all of the aftermarket stuff starting to show up. When the bronco was first released, I could do a complete assembled SAS or BL setup for $2K or less, shipped. For whatever reasons (supplier price increase or greed) it's now cheaper to get the Ford Accessory shock kit, plus you get some lift. I know the BL and SAS folks aren't able to partake so the only option there is aftermarket. I would like to put 3.0 on my BL just for S&G but even doing it at cost, doesn't make sense. If you could get a set of take offs that match your config for a good price, then yes.
FreddieLee
Freddie
With several aftermarket options in the same price point why buy the OE Fox shocks?
I’m going to assume that most folks want them because of the on-road and off-road ride quality. Personally, I haven’t seen any direct comparisons between the HOSS 3.0 suspension and an aftermarket coilover suspension. What you hear a lot of is comparisons to the Bilsteins. Also, a lot of folks like sticking with OE equipment for warranty purposes.
NaMinesClarence
Northern Metro MN
22 Badlands Sasquatch
What's the difference in a warranty application if you have Bilstein 6100's/Eibach coilovers or Fox OE?
For the cost of admissionI find the OE Fox shocks a little steep. I look at the external reservoir on the OE Bilstein and Fox shocks as more of marketing than performance.
Binky
Where it snows a lot
Depends on the day
Is that accessory shock kit PN for the 2-door, non-SAS Ford M-18000-B1A?
Wait, derp, I found a better description... https://www.levittownfordparts.com/sku/m-18000-b1a.html
Not a bad deal for a bolt in 2" lift and suspension "upgrade" without going the HOSS 3.0 route
tank300
West Lafayette, IN
22 Bronco Base + manual + Sasquatch package
I am thinking swapping the fox shocks as well. I have a Base 2.3 Sas package + manual. All the Ford parts websites indicating the part number only work with the 2.7L v6 model. My Bronco should be lighter than 2.7 +10AT. Would it be an issue?
broncosor
2022 Bronco Badlands
There are so many reasons I and others want the 3.0 over after market coil overs.
Warranty, keep stock height (I don’t want to increase roll over risk), cost because aftermarket fox is 5-6K and these seem to be less, factory tuned. Etc.
flip
Phil
IN
www.ruxerparts.com
Fords
Fair enough. I was looking mainly at the cost vs. gain side of it. If budget isn't an issue then I would definitely recommend using OE when possible for several of the reasons you laid out. Having not driven anything with 3.0, I can't speculate on the difference in ride between this and 2.0. I think Ford wants too much for their stuff which sucks because I really think we could sell more of the performance stuff if it was about 25% less.
Eroc88
Ohio
Jeep
Just curious with these being VIN specific, could the Hoss 3.0 be installed on a BL non SAS?
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Yes. The attachment points are the same.
FreddieLee
Freddie
Is there a definitive answer regarding the part numbers for a 4dr Bronco?
