- Eric
- Apr 30, 2022
- 1
- 14
- 16
- Fort Walton Beach Florida
- 2022 Outer Banks 4 door
- Outer Banks
I've done a lot of suspension work in the past but this Bronco is beating me up pretty bad!
The axle nut galled up the threads on my axle shaft when removing it which is obviously a giant pain but turns out it's not my biggest problem, also my CV joint separated when I leaned the knuckle to remove the strut. Which is also not the biggest problem of the job. Ordered a tool from Amazon that fits in a Dremel that restores threads- which works great if anyone has the same trouble I've had. Ordered new axle nuts from Ford which were surprisingly only $3 bucks each. While talking to the parts guy he asked if I worked at a local 4x4 shop? Come to find out the local shop had ordered two nuts and a new axle. I called them to see if I could buy a nut from them since mine was dead in the water. They've got two down in the shop for the same reason. Lol I didn't feel near as bad hearing I'm not the only one having trouble. Picked up the nuts I ordered and attempted to put her all back together but the axle just wouldn't go back together. Tried for a while with no luck. Decided to clean up the shaft to see if there was a keyed spline or something I was missing and I found the problem.
Emergency ordered an axle shaft hopefully I get it Monday or Tuesday. What a mess! How the heck did this axle shaft get so hammered in less than 2000 miles?? The CV separated way too easy I'm guessing it was never fully seated from the factory. But I still wonder what the heck beat up the shaft so bad??
