- Patrick
- Mar 10, 2020
- 13
- 256
- 633
- Northern California
- 2022 Bronco Badlands Sasquatch 2.7L
- Badlands
Thanks for the added comments - I'll likely start with #5 setting and see where that gets me.First off I am Liking these even more now that I returned from a long road trip with some more off-roading thrown in. Off-road still about the same performance and feel of the stock sasquatch set-up but on twisty mountain roads they really do add improvement in control and feel. Plus it just looks better!
Funny you should ask about the headlights. Someone flashed me for the first time since last night. I've had it for almost a year and 12k miles and that was the first time. But I don't plan on adjusting the lights. One out of hundreds if not thousands of people I have passed since the install tells me I'm still good and I like the beam pattern.
As far as the adjusting the clips after install I'll have to look. There are several ways to do it on the vehicle( plenty of you tube videos), but obviously better to pick the height you want from the start. I've done it in the past on my Tundra and it wasn't bad. UCA's are not necessary at 2" lift or less. I would maybe start to think about it over 2" but I have yet to see any posts about anyone not being able to get it back to proper alignment. Les Scwab had no problem with mine at the #4 setting which was supposed to be 1.7" lift but gave me exactly 1.5".
My suggestion is to pick your front end height the way you want it. Go with the higher clip setting if you are on the fence between two heights, the rears can be done in less than 30 minutes each (1 hr. total) so you can adjust that height up or down really easy if you want to change the rake.
What vendor did you purchase the 6100s from?
