NOW I WANT AUX SWITCHS DILEMMA - HELP!!!!!!!!!!!!
CALBEETX
Christine
Austin
Bronco/ Bronco Sport/ F150
So I have been through so many threads it is making my head spin - I just want to make sure I am reading this correct. If I did NOT order the AUX switches it is NOT plug and play. It is semi wired but not all the way?! I ordered an Outerbanks without Aux switches b/c I am a dumba$$ - installed pod lights and LED light bar ordered the OEM console assembly/ switch assembly - but cannot figure out how to connect. What else do I need to order?! Please help me.
tobands
2022 Bronco OBX , 2014 Escape Titaimium
to be safe , I would talk to the dealership and have them install..
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
It seems like they are some vehicles/trims that are delivered with the components for a plug and play switch unit install, and some that are not.
Check out the “adding switches after delivery” thread for forum member experience and relevant part numbers and diagrams
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
I read the original thread mentioned above and I believe they determined that the wiring harness is not in either A pillar, and it requires a different overhead console part number. So, I went an easier route and got a 6 switch panel. It fits nicely in the gap in the hero switch panel. Used a mount from Bullet Point mounting solutions, with 1/4 20 1” ball to hold it.
Ford Bronco NOW I WANT AUX SWITCHS DILEMMA - HELP!!!!!!!!!!!! 6E34C348-1510-4CBE-AF62-A92B47E9B64D
j_marinelli
Spring Branch, TX.
Copperhorse73
Justin
Mooresville, NC
CALBEETX
CALBEETX
Christine
Austin
Ford Bronco NOW I WANT AUX SWITCHS DILEMMA - HELP!!!!!!!!!!!! 1632600337366-
What after market switches did you buy?
CALBEETX
CALBEETX
Christine
Austin
Thank you - but I do not find that thread is it called something else?
flip
Phil
IN
www.ruxerparts.com
Fords
Part of the problem is the harness going from the passenger A pillar is different from AUX to non-AUX. I posted the P/N in that thread but never heard if anyone verified the wires to the A pillar connector were there. If so, there's a good chance it might be plug and play since most have the wires under hood already.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
