Ordering advice, to Squatch or not to Squatch?
Naxster
Dayton
None
So I'm going to order a Badlands, 4 door, 2.7L, AT.
My ultimate goal is to lift it with a proper lift that drops the front diff, and put it on 37" KO2s with beadlocks.
With 37s and rock crawling in mind, I'd like the better gear ratio of the sasquatch package, and the wide fender flares. On the other hand, maybe it would be cheaper / easier to just replace the diff gears and flares afterwards?
I don't care for the sasquatch wheels/tires that much, but I do like the non-sasquatch bead lock wheels.
Non-sasquatch beadlocks wheels: $995
Wide OEM fender flares online: $500
Sasquatch upgrade: $2,495
So, I have a few questions.
1. On a Badlands, the only difference between non-sas and sas are the wheels, tires, wide fender flares, and differential gear ratio. Right?
2. What would it take to re-gear the diffs? Any estimation on prices? I'm an industrial/commercial HVAC tech, no stranger to tools and taking things apart, if it was a typical diff I wouldn't be worried about it, but I don't know if these locking diffs are a whole other ball game, or pretty straight forward?
3. Do you think I can get 37" KO2s on either of the 2 beadlock wheels with a 2-4" lift, without much rubbing under compression while turned full lock, or do you think I'm going to need aftermarket wheels with a different offset?
4. Depending on the answers to these questions, my current route is sasquatch. Then lift it when a decent kit is available (like the new RC 5" lift, but it's not compatible with badlands) and put it on 37s. What route would you take?
Manotick Badlands
James
Ottawa ON
I think the non SAS Badlands is perfect. I ordered a Wildtrak which didn't get built and bought a non SAS Badlands off the lot. I'm glad it worked out this way for me. Aside from saving thousands on the vehicle price itself I recently realized I would've had to buy snow tires for the SAS, which would've been thousands. I'm going to run the KO2s year round. Beyond that the Badlands has a 4.7 rear gear ratio already. I do think the SAS has 1" extra suspension travel. If I'm wrong I'm sure someone will point that out. Non SAS Badlands for me!
Naxster
Naxster
Dayton
None
According to the build and price, the AT comes with the 4.46 diff, you have to upgrade to SAS to get the 4.7
jedmisten
Joseph
CA
Ford Ranger and Ford Flex
In the BL, you cannot get the 4.7 gearing without SAS or the manual transmission.
Drex
Jake
The 5% gearing difference isn't worth the cost of a re-gear. If you feel that you need to re-gear on one set up, you will feel the same need on the other, so that is a wash.
If you are going to lift it, not much point in getting the Sasquatch.
The $995 optimal beadlock wheels are a half inch less wide than Sasquatch wheels, that will somewhat limit the sizes of tire width (you did not specify) you can mount. Even with tire specifics, I don't think anyone who hasn't mounted the same size wheels and tires can tell you if it will rub under those conditions, especially since you have listed a 2, 4, and 5" lift as possible..
Drex
Jake
Functionally correct, but backwards; the BL comes standard with 4.7 gears, you cannot get 4.46 without ordering the optional automatic (or 2.7 that forces the automatic) without Sasquatch. Works out the same, but reverses which is optional.
jedmisten
Joseph
CA
Aren’t we saying the same thing?
dgorsett
colorado
F250, Mustang, Explorer
Get the non Squatch, 4.46 or 4.7 you won't notice the difference, and don't waste your time with a gear swap.
CDNMXRACER678
Otterburne, MB
2021 ford bronco BL, 2017 FoRS, 2020 F-450KR
The offset is also different(+30) on the SAS wheels(17x8.5)
Putting 35” tires on the non-SAS wheels will interfere with the control arms.
The non-SAS wheels are 17x8 with a +55mm offset
Ford Bronco Ordering advice, to Squatch or not to Squatch? 0A21E7DB-1F5F-4E5D-9600-DD7DB2BBF5D4
DonM
Don
Northern Cincinnati
2021 4DR Base Sasquatch 2.3 in VB
Get the Badlands and build from there. The big bonus of the Badlands is the auto disconnecting front sway bar. It and the FE are the only models with it and sounds like a really good option for rock crawling. I don't think gearing is going to make much of difference until you get over 40" tires.
I went Base Sasquatch because I wanted to stay in the lower price range and don't really need the disconnect. I may even drop to 33's at tire replacement.
J.Spicoli
J
CO
I was looking into the sas vs non sas differences question as well and somewhere someone mentioned the SAS has 10mm (0.5") larger bumpstops to limit wheel up travel in order to keep the larger tires from rubbing during full tuck. Not a huge deal but it is something I've found on here.
TheWoo
Manhattan, KS
2021 Gladiator Mojave
Just for clarity, as I don't think anyone posted it, but this is incorrect. The SAS suspension - even a Badlands SAS - has slightly less wheel travel than the standard Badlands. It's simply a feature to limit the up-travel with the 35s. It's a small amount.
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Compta38
Alabama
Ford Fusion
You could sell Sasquatch wheels and tires to make up a big chunk of the $2500 upgrade.
