Bikeric
Tulsa
1984 4Runner (For Sale)
That looks like a Great solution!! Just remember to use OFC wires (true copper) and NOT CCA (Copper Clad Aluminum). Opening and closing the tail gate would cause CCA to crack over time, and not be good.
WillinMA
Will
Groton, MA
2021 Wildtrak, 2020 G Wagon, 2018 Audi R8 Spyder
$1400 - that included amp, box, sub, control switch, and install.
I also spent about $500 replacing the interior speakers with higher quality ones.
I have the B&O system and upgraded all the speakers first...then just added this sub. Did the install myself and to your point fits like a glove in the rear door - with the B&O, I took out the sub along the side and thats where I put in a Kicker Key500.1 amp (inside the sub box) to drive the sub. Along with the speaker upgrades, it now sounds like a decent setup. I also dynamated the floor of the cargo area while I was at it...and you do have to make sure the sub is mounted with all the screws into the box and the box mounted tight on the rear door - or else you will get vibrations while playing your music!
BWahlberg79
BWahlberg79
Montana
What did you replace the stock speakers with?
Audison 4" in the front dash and rear bars, Audison 6 3/4" in the kick panels. That really helped with the clarity of the sound - but since the kick panels are basically at your feet it really limited the ability for good depth. Add in the rear speakers are just 4"... so yeah - quality upgrade, but no bass upgrade there at all. The sub fixed all of that, and then some.
OBXSquatch21
Nick
Kansas City MO
Toyota Camry
I know MTI had mentioned they put dynamat between their tailgate box and the metal. Did you do that on this version?
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
I'd be much more inclined to take apart the tailgate and put it inside, in the case that you want to remove the sub box at some point, you don't want dynamat sitting there visible.
Hossfire
Richmond, VA
'06 Jeep Commander
That clean. Think im going to copy when mine lands whenever lol
I may consider that as well. I have been itching to build a sub box for a while.
Yardo //
Santa Fe, NM
2011 Lincoln MKX (for sale), 1976 CJ-7 (for sale)
On the list!
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
had it done professionally bc I would mess it up. Added a RF amp for power management (hid that under the front seat) and added a volume control knob on the dash.
Whoa… the sound is great. It just what’s needed to add good depth to the sound. I didn’t order the upgraded audio - this though far exceeded my expectations.
It also fits pretty well and with the shallow 12 it doesn’t take away from storage space in the back.
Here’s some photos, I’ll get a video of the sound and follow up.
I was set to go this route during my stereo install, but then balked at it because I really wanted my flip down table in that spot. I haven't come up with any better idea yet though, so I may have to bite the bullet and have the Stinger put on.
Do you think there is maybe too much weight on the tailgate? It already feels heavy just with the spare on there.
BWahlberg79
BWahlberg79
Montana
It's seemed just fine to me, granted this is day 2 with it. Opens/closes just fine, doesn't seem to have any excess stress on it. Considering Ford built the tailgate with the intention to add accessories to the door I'd venture they designed/planned it to support plenty of weight.
WillinMA
Will
Groton, MA
I just watched the install for the MTI and didn't see on their install any dynamat between...but the one thing I did notice is the different ways they mount. On the Stinger you drill 4 holes (template provided) in the tail gate...the two bottom bolts attached an L bracket that holds up the box and you screw the bracket in the box (from the bottom) as well. Then there are 2 up top as well. For the MTI, the bottom looks like it slides into a slot and has just 2 bolts in the center to hold it in place. On the stinger you can pretty much get max bass for a 12" woofer and not get any vibrations from the box/tailgate. It appears that the stinger (though more holes to drill) mounts more securely....but thats just one person's opinion!
Rem234
Illinois
20 Veloster N, 11 Buick Regal, 02 Lesabre
I put a piece of rubber sheeting between my box and the tailgate. This way there won't be any adhesive on the paint, and the box isn't touching the paint. Besides the plastic cover sticks out further than the painted panel below, so this helps to square up the box.
Most of the inside of the tailgate is full of bracing and honestly I could not see anywhere flat enough to put dynamat. Perhaps with a spray? The only rattle I get is immediately around the handle, and only with certain songs/frequencies. So eventually I may put a bit in that area.
I feel the weight of the spare tire, coupled with the weight of the sub and box (30 lbs for mine) gives the tailgate so much mass that it doesn't rattle or vibrate.
jacobrdoty
Jacob
Sacramento, CA
2013 Mustang GT (Bagged and Boosted) x 2022 Bronco
In the exact same space. I found this : https://srqcustoms.com/product/ford-bronco-subwoofer-enclosure-with-grille/
I was leaning toward this as I don't have the OEM B&O system so I can trim my opening and add that grille.
