Depends on what you will do with your Bronco. If you do rock crawling / tippy stuff then yes. If not, then maybe not.
20-30 mph would be a pretty reasonable limit.I’m pretty sure it reconnects at 20mph. I can’t find the source but will update with a link as soon as I find it.
You bring up a good point about improving the ride quality over bumpy trails. Hopefully ford allows us to somehow cancel the reconnect.
This will be interesting to see as well. Because with some GOAT modes it will lock the diffs for you.Does anyone know at what speed the Front and Rear lockers engage/disengage? Might be fair to assume the sway disconnect is the same speed?
I hate when vehicles automatically re-engage traction and/or stability control at certain wheel speeds, which leads to cutting power / wheel speed.This will be interesting to see as well. Because with some GOAT modes it will lock the diffs for you.
For example: The Mud mode will supposedly lock the diffs (if you have them) and switch to 4-hi. Wheels speeds can be high going through some mud. I would hate for my lockers to unlock as I'm trying to keep wheelspeed up to keep the tire tread clean.
I agree 100%.I hate when vehicles automatically re-engage traction and/or stability control at certain wheel speeds, which leads to cutting power / wheel speed.
The traction nannies re-engaging when you are trying to climb a sand dune, get out of a mud hole, or even get up your icy driveway can be a huge pain. In those situations, I don't want the vehicle to make any decisions for me, whether it is lockers, sway bars, or traction aids. I want the vehicle to do what I tell it.
As excited as I am about the Bronco, part of me does not want to take any modern vehicle off road. Does anybody remember how several Colorado ZR2s deployed their side curtain air bags when owners were driving off road? I have not been following those closely lately, but I know they did release an updated calibration for that. It was not any fun for the first few owners that had that problem, as GM was not quick to offer any help.I agree 100%.
When I'm at the dragstrip in my F-150 I have to remove the ABS fuse so I can do a proper burnout. Even if I turn traction control off and Advance trac off is re engages when wheelspeed hits a certain limit. It's super annoying.
I think it may be more challenging to keep the sway bar ends out of the way on an IFS vehicle once the end links are disconnected. I can't think of any other reason disconnect kits are not more commontly available for Tacoma, 4 Runner, Ranger, Zr2, and other popular IFS off road vehicles.Did a google search and didn’t see any real options for aftermarket front sway bar disconnects for the Ranger. Plenty of options for the Wrangler, though with SFA probably easier to engineer than for IFS. More than likely not springing for a Badlands. Here’s to hoping the aftermarket provides some solutions!
I have an elecrical rear locking option one in my F150 it depends on terrain mode. its 25 in 4H/4A and 62 in 4L which I have never tried lolDoes anyone know at what speed the Front and Rear lockers engage/disengage? Might be fair to assume the sway disconnect is the same speed?
