Turning off double horn beep when exiting vehicle while running????
Grumpy
Who's
On a Lake
22 2dr
I fish Monday thru Friday and tow my boat doing so. When I get to the boat ramps I have to exit vehicle to unhook boat and when I leave I have to exit vehicle to drive boat up on trailer. But that damn double horn blowing alert when exiting while vehicle running and key fob in pocket drives me nuts. Is there a proper way in settings to turn that off? I've looked throughout the setting can not find option to, and visually scoured the electronic vehicle manual, and nothing.
Grumpy
Grumpy
Who's
On a Lake
22 2dr
Is it by chance the mis-lock setting?
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Grumpy
Grumpy
Who's
On a Lake
22 2dr
JediMcMuffin
Tommy
2021 Bronco Badlands
Thanks bud, I guess I need to educate myself on what forscan is. Ill read it now!!
Its got a bit of a learning curve, is this is the only thing you need from it, make a friend who knows how and ask them to do it. You'll need a wired or bluetooth OBD module, and a Windows 10 PC.
Roger123
Roger
VA Beach, VA
Drives me nuts too, I've gotten to the point of just closing the door to the first latch point, not fully closed. This will keep the horn from honking.
FleshTuxedo
A
PA
'22 OBX 2dr.
Sooooo f*cking annoying.
I wish Ford would make an option of this on a future software update.
Grumpy
Grumpy
Who's
On a Lake
22 2dr
There is 2 items I want to do
1- double honk disable
2-change tire circumference parameter
I just got done watching the YouTube video about forscan on this site. I will be buying the obdII module the video suggested and register with forscan for the user license. I have a laptop w/windows current version also.
Thanks bud
Eric L.
Wi
2020 SQ5, 65 Mustang, 67 Coronet
Superchips flashcal might also be an option for you. Doesn't seem to be available for 2023 models yet though.
SasquatchMansquatch
4 door basquatch
I can see why this would be annoying.
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
Thanks bud
3. Disable automatic idle kill switch
Headsong
They should be sued. Someone will have a heart attack....
clyde6g
Trever
FL
1972 Valiant
https://www.bronco6g.com/forum/threads/introducing-pandascan-our-remote-forscan-service.64954/ check this out.
Grumpy
Grumpy
Who's
On a Lake
22 2dr
Can I accomplish both those items I want to change with flashcal? Any ford warranty concerns using it? I know on my 15 GT I had a programmer and had to go back to oem settings every time I had a service appt.
Eric L.
Wi
Yes. No clue. I was looking into getting one for the reasons you stated. I won't purchase untill I can conform it works with my 2023 without causing an issue.
