- Joined
- Jul 14, 2020
- Threads
- 125
- Messages
- 6,164
- Reaction score
- 7,045
- Location
- California
- Vehicle(s)
- Jeep Wrangler JKUR
- Your Bronco Model
- Wildtrak
Had a water leak in my XJ coming out the bottom of the door frame by the A piller. After spending bucks to replace the door rubber and a new windshield (needed one anyway) still leaked.
Then I got smart and took a systematic approach. Taped a bunch of garbage bags and uses blue painters tape around key points including window seals door jambs etc.
Then busted out the garden hose and soaked the outside to make sure I got the leak. Then, started at the bottom and slowly removed the bags/tape from key sections, testing each time.
Got down to the last bags that only covered the roof rails and bingo.... Water was coming in from a roof rail bolt.... $3 tube of sealant on all the bolts and the problem was solved.
My point, reproduce the isssue, then cover everything to verify you got it, then start at the BOTTOM and work your way up.
