4” Speaker Harness Pics
Erock
US
2018 F150 Alpine edition
Infinity always sound a little high pitched to me… so cutting out the mid bass range would definitely hurt them. Only my opinion though.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I must say, I just installed the 600hz Bass Blockers from Crutchfield on the Infinity Ref this morning and they sound INCREDIBLE. Evened out the sound and plenty of bass. Only got to the dash - but, what a difference.
Portapot
Portapot
Maryland
Cj7, RX350, f250,
Yeah mine did too until I Installed the infinity kappa 6.5”s then I lost a lot of bass and they sounded to pitchy. But hey it’s just one man’s opinion. I think the fact the factory is not a coaxial it drives more bass than the coax kappa…. But I’m not an expert . The bass blockers on the 4” speakers helped a lot. Matter of preference on how much you want to block. I wonder if I should block some of the higher frequencies to the kappas if that’s even possible?
redone17
Cold Spring, NY
@Portapot - interesting. Don’t plan on touching the 6.5” at this point. I’m happy with where it’s at. I’m not willing to lose cargo space for a sub. So, dialing in settings with the current setup.
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
Cargo area is certainly a premium in these... How about under the seat? The Kicker 46HS10 is really small for what it is.
redone17
Cold Spring, NY
I’m just going to ignore this idea/post.
WARPIG
Ohio
74 Bronco, 17 F350, 05 Jeep LJ, 06 Jeep LJ
I just ordered Kicker 2 way 3.5 inch. I'm splicing. Im not waiting around for 5 different connectors, 4 of which wont work.
besides I ordered a Bad Lands, and I'm driving a Big Bend. Once my BL comes in, I'll know what works.
campbebc
Ben
Waterford, VA
2021 Ford Bronco, 2004 Mazdaspeed MX-5
FATHORSE
Stephen
okc
nissan
I have seen that photographer before!
Ford Bronco 4” Speaker Harness Pics en_bigfoot_free
redone17
Cold Spring, NY
Haha. I was just referring to finally being happy with the outcome...then being tempted to spend more $$$. I really am happy with the current setup. Of course, it can get better. But, I have a few more mods that are priority before spending more on sound system. Bookmarked for sure!
j_marinelli
Spring Branch, TX.
zzcoop
A-A-Ron
Kansas
www.postrockimages.com
2021 Bronco Black Diamond
Pin is 1mm wide and .62mm thick. I'm sure there are some premade terminated wires available but that would add a little $ and require some soldering or butt connections. Still need to put some heat shrink on but it's ready to go.
Sweet! I'll take four.
Ford Bronco 4” Speaker Harness Pics money-money-money-make-it-rain
zzcoop
A-A-Ron
Kansas
I'm still waiting on my BD to bust out of the corral, but I've picked up a full set of Rockford Fosgate Primes (seem to be a great bang-to-buck ratio with those from what I've seen) which all have built-in crossovers, so I'm curious how much (if any) benefit that will have regarding the need for bass blockers. They'll still be getting the full frequency range, but hopefully it will be much better optimized and keep any distortion to a minimum.
Just need to figure out what to do about connecting those pesky 4-inchers… I greatly prefer a plug-n-play adapter if at all possible. (Or by simply bribing @flip to do the DIY method properly.)
JediMcMuffin
Tommy
2021 Bronco Badlands
I am hoping to just use positaps behind the factory plug, hopefully there is enough space there. What's the gauge of the wiring? I like the idea of having a pigtail though, so I may yet order the molex connectors, I just don't want to own another crimper that I'll use once.
zzcoop
A-A-Ron
Kansas
Not sure on the gauge, but I was looking into exactly this just this afternoon, as a matter of fact. I'm leaning towards going this route myself. Seems to be the least intrusive/destructive method until a ready-made harness adapter is available. Just tap the bass blockers in behind the factory harness, then once a proper adapter is available, change out the connections. Voila!
