Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
My rack and pinion just broke. I had the full bronc buster steering. 2 door sas no other mods but full bronc buster steering stuff. Once ford takes it out I’ll ask for pics.
Just curious if you reached out to Bronc Buster yet. I'm assuming when you say 'full', that includes the bushing, braces and aluminum housing end?
Just curious, but what were you doing when it broke? Not trying to criticize, just curious as to get an idea of the level of durability of that setup as I have the same setup as well.
TeocaliMG
Plymouth Michigan
2021 Bronco Badlands non-sas 4 door manual
Yayyy, and it will only cost $20k!
I am assuming this will be hydraulic, curious to see how they implement that to the FEAD, shouldint be impossible. Assuming it wont be an in-house EPAS system since I have first hand experience seeing how hard that is to do at the OEM level.
I wish 74 weld would consider making performance upgrades targeted more toward the enthusiasts than exclusively pro race teams (and their coffers). Their portals (and no doubt this steering gear) are absolutely bomb proof, but what the heck is the point when you are still dealing with a midsize class pickup frame...
Make some portals that cost 5-10k and can handle enthusiast level wheeling on 37's or 40's. We want portals for fun, not trying to win 4600 class ultra 4 here...
Crzr45
Jason
Pismo Beach , Ca
Fj60,BJ73 Landcruiser’s
Dream_Solventless
Zach
22’ Bronco
Tires size is stated. 2 door sas only mods are bushing, housing and tie rods from buster.
I took the vehicle off road once before installing busters stuff. What I did was not even crazy. Level 1 stuff at most
I don’t know what broke. Ford says I need a new rack and pinion. That’s all. I’ll try and get pics.
You installed them but took to dealer to diagnose and I’m assuming fix? Im leaning towards improper installation, but I hate to point fingers so fast. Curious to see how this plays out, because I think you’d be the first with a broken rack with his fixes.
zuke
Stafford VA
We have members that every place their rack with the HOSS 3.0 And they had to do a lot of tricky stuff to get it to program including using two different pieces of software.
So how exactly is this company stating that this is going to be plug and play when we know that the steering rack contains an actual module that has to be programmed? One of those programs is Fords, requires fairly expensive adapters, it had a minimum of $50 two-day license fee.
The shenanigans we had to do to get the HOSS 3.0 rack in was to get the programming (Firmware if you will) into the rack that Ford provides with a blank slate.
If 74weld is providing a rack that already has a program in it, and that responds on the canbus the same as the stock rack it's repacing, It will be plug and play.
The question there becomes if the stock racks all respond the same, which I don't think any of us hobbiests have figured out, But I'd bet 74weld has..
Ramble_Offroad
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Per the IG chatter Loren H will be testing this rack on 40’s.
So…..my question is are we talking about a hydro system targeted at the dedicated rock crawler or race community? Or a durability improvement over the Hoss 3.0 targeted at consumers who wheel & daily their rig on 37’s?
I asked the same question on IG. No reply yet. (Edit: see screen shot of reply below, electronic not hydro, etc)
Let’s just suspend the high cost potential of this item for the time being and pretend it won’t be cost prohibitive. No chatter about programming yet either which is notable.
Personally I’m interested in upgrades that enhance durability but don’t create a trailer queen. I like to drive my vehicles not tow them
TeocaliMG
Plymouth Michigan
All of this is why I will be beyond surprised if its a true rack EPAS. My money is on hydraulic and a code clear + "suck it up and ignore the cluster warnings". I don't see them diving into mechatronics (hard enough for Tier 1 suppliers) unless they are just building a shell for the existing mechatronics, but that sounds like a business nightmare...
zuke
Stafford VA
Not sure that would even be possible for a street driven Bronco though.... the Steering control module that lives in the rack is a peer module on the bus, if it isn't there, I'm guessing the AWD Module and ABS Module are both going to lose their minds, and the PCM is going to at least be a bit upset...
You can do that kinda think on a race truck, and that might be the only place 74weld plans for this rack to go. But if they plan to put it on the street, a christmas tree display on the dash will not be an option.
A shell for the mechatronics is an option too, as you mention... IAG was working on something like that for the front axle disconnect when upgrading an M190 to an M210.
swooshdave
Portland, Oregon
Mustang
My vote is for a steering rack that is off-road only, or at the very least defeats all of the steering nannies from Ford.
StoicAF
Kyle
texas
2022 Bronco
I reached out to Tyler. He doesn’t think my rack is broken. He thinks I got mud and water in it. My tie rod boot was not seated correctly. I am seeing him Friday and we are going to fix the issue.
im so glad he lives an hr from me.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
So billet housing, going to guess $2500 for just the housing. Hard part is going to be taking the pinion assemble with integrated control board.
They do lose a little credibility with HOSS 3.0 rack comment, definitely has a more powerful motor and metal top plate over the pinion.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Boom. Feedback from IG post.
Yeah, this was my take. Much like the Billet Housing BB has, make the rest out of Billet, leave as much meat anywhere you can for strength.
I have to say I have thought of the possiblity of using structural epoxy on the outside of the stock housing to beef it up. Forming it up in areas that are weak, and that it has space on the outside to still fit..... who knows.
Desert_Brush
SoCal
2015 Mini Cooper
At what "bigger" tire size are people breaking these off-road?
