Actual Towing Capacity (help)
BadazzBronco
Tamar
Phoenix
Nissan
So, as you can see... there's some MAJOR squat on my girl! Part of the problem is the golf cart batteries which weigh a combination of 120lbs 😆 🤣 😂 we're replacing those with a 20lb lithium battery before I hook her up again! The pop-up's dry weight is right around 2400lbs which is well within the 3500 MAX.
Another issue is the spare tire, the rhino hitch is just shy of about 1/4 of an inch from raising to the top notch which would also alleviate some of the squat.
Any thoughts on carrying an air compressor and letting just enough air out of the spare to raise the hitch?
Ford Bronco Actual Towing Capacity (help) 20230607_141009
Ford Bronco Actual Towing Capacity (help) 20230607_135330
Ford Bronco Actual Towing Capacity (help) 20230607_135320
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
It’s not about “can the Bronco pull it” - it’s about “can the Bronco stop it” That and “what will the Bronco do when that heavy ass trailer starts swerving left and right”
Odds are you can tow just about anything with your Bronco. When I was younger, I towed overweight a lot. But then, one day, the odds caught up with me. Cost me my Nissan pickup and the Jeep CJ7 I was towing. Along with a trip to the hospital. Where, Mr. Policeman was waiting for me to add insult to injury in the form of a $500 ticket. Which was a lot of money back in the 1980’s.
It could have been worse. No other vehicles were involved so nobody else hurt and no pesky lawsuit to defend against. I was lucky. Maybe you might be too.
Needless to say, I pay more attention to towing capacities these days.
What doesn’t kill you makes you wiser
BadazzBronco
Tamar
Phoenix
Nissan
I appreciate your reply and understand your concern.
My pop up weighs in around 2400lbs, so I don't necessarily consider it a "heavy ass trailer" since it's well under the 3500max ... but I could be wrong.
If I cannot find resolve with the squat issue, I will have to figure something else out, but for now....I would like to at least try to make it work.
mpeugeot
So does this look like too much trailer for a 2 door Bronco?
Ford Bronco Actual Towing Capacity (help) IMG-13df2e0ef0896bc6fe2315cf99c6ee3f-V
It's a 16 foot trailer with all the basic creature comforts including shower, toilet, AC, frig, etc. Can sleep a maximum of 4.
Dirtylqqks
Keno
Bullhead city Arizona
2022 badlands , 1969 ford bronco 2021 scatpack
So many what if and well maybes , so after doing some research and losing the rear spare tire and replacing the coil overs and adding a little preload to get a not so sqUATTED ride. I settled for a 2021 inTech flyer pursue . Loaded down tongue weight rolls in at 350 plus or minus 15lbs depending on how loaded and well I’ve burned off a few thousand miles and let me tell you. Its tows amazing . Running the lock and roll hitch with a bit of a riser on it it seem to tow the same wether its up or down. However i totally agree with everyone on here who has said it. BRAKES BRAKES BRAKES … THEY SUCK so before you run out and try to max out the load protect yourself and make sure you have electric brakes. I’m in the process of reaching out to the great guys in lasvegas at EBC and see what they can do to help me stop the bronco. I did it on my jeep and it was night and day literally…. Safe travels everyone and thank you for all the posts that helped me get on the road…. Mountain pic was before lock and roll and preload adjustment.
Ford Bronco Actual Towing Capacity (help) IMG_3494
Ford Bronco Actual Towing Capacity (help) IMG_3144
Ford Bronco Actual Towing Capacity (help) IMG_3253
JoeDirt
Joe D.
Southern Utah
2016 Ram 2500 4x4, 2017 Mits Mirage
I"ve been looking at similar. But I need ability to carry kayak, a cpl bicycles, a 250 quad or 2 small motorcycles (not all at once). SunRay is an option and so is Dune Sport.
Also, most of my towing would be local (under 300 miles one way) and I wouldn't be filling up on water until I arrive at my destination. A weight distribution hitch will also be needed.
JoeDirt
Joe D.
Southern Utah
What is the total tongue weight of your setup with batteries n propane. Weight distribution hitch might help even things out. Broncos only have a 350lb tongue allowance.
BadazzBronco
Tamar
Phoenix
Nissan
THANK YOU for responding!!!
We were over 400lbs... Those batteries are really heavy, 120 lbs. Once we switch those out for the 20lb lithium, I will weigh again, hopefully I will be under 350. Can you recommend a decent
weight distribution hitch?
JoeDirt
Joe D.
Southern Utah
I need to check into them myself. I've been towing (Ram 2500 w/21ft Attitude Toy Hauler with weight distribution hitch) for almost 20 yrs.
I'm still learning the specs and capabilities of this (Bronco) short wheel based veh myself before I get a trailer.
But most weight distribution hitches should work.
One last item. I really don't like towing on one axle trailers, but this is a Bronco with sever weight limits.
I would possibly look into a better rated tire than came with your trailer.
BadazzBronco
Tamar
Phoenix
Nissan
Thanks a ton for the helpful information! I really appreciate it!
I know towing is limited, which is why I went with this trailer... hoping it all works out in the end!
AZSky
Scottsdale, AZ
Heritage, Mach E, EV6
Dirtylqqks,
can you provide more info about the coilovers? Does it void the warranty?
By electric brakes, you mean in the trailer, correct ? My Mammoth Overland has them.
Did you buy anything from EBC ?
BadazzBronco
Tamar
Phoenix
Nissan
So, we changed out the battery yesterday and switched to smaller propane bottles... went from a 2-inch squat with over 400 lbs of tongue weight to 3/4 of an inch of squat! What a huge difference. My friends that I share the pop-up with have a RAM with an astronomical tow rating, so we weren't too concerned with weight since the Bronco took so long to get. We knew we would have to make adjustments... I am still looking into a weight distribution hitch. Keep me posted if you find one you like.
Brocky
Maryland
2022 Bronco
I want to camp this year and take advantage of being able to work remotely. I love my Bronco (21 Badlands, Squatch, 4DR 2.7) but am struggling to find a good sized live-in camper that could be towed relatively safely.
If the limit is technically 3500lbs and a camper weighs 3500lbs dry, roughly 4100lbs loaded, is that truly above the limit? Also new to towing something other than small boats/jet skis but understand the basics. Any input would be so greatly appreciated!
Yes your over by 600 lbs. But it is not a lot over. I would definitely have a brake controller which I have on mine and will help with stopping. I had a transmission guy tell me years ago that manufactures reduce their towing capacity on purpose to reduce warranty issues. His opinion is mainly due to transmission issues, which in my case with a f150 I had more capacity than what manufacturers limit. Always be smart & responsible with towing and don’t drive it like a race car.
Definitely use brake controller if your trailer has electric brakes.
LETSGOBRANCO
Gary
Ohio
If you are only going to travel with the trailer and leave it at a camp site while you explore the trails in the Bronco. I am looking at getting this Coleman Lantern LT 17B. 2986lbs dry weight. Just watch how you load it and the bronco. I am sure you can keep it under 3500lbs or right at the limit to stay legal. The Bronco has no issues pulling it and the curt wireless brake controller worked beautifully for me. I see many jeeps pulling this RV as well and they have the same towing capacity as the bronco.
Hello can you tell me what the model of your camper is?
mygreenbronco
Keith
Washington
1973 Bronco
I have a question for all the towing police out there. How do they weigh your camper after an accident when you hurt somebody? If you're overweight, do they put all the pieces back together? Then fill all the tanks with water and propane and fill all your fridge with food and beer? And then weigh the camper? How do the know how much tongue weight was on the camper?
