- Joined
- Dec 20, 2021
- Threads
- 31
- Messages
- 454
- Reaction score
- 552
- Location
- Cincinnati
- Vehicle(s)
- Tacoma
- Your Bronco Model
- Big Bend
- Thread starter
- #1
Just thought I'd post some pics here since I have not seen anybody running the "safari" bimini yet - this one does not have the zippers/middle bar that the other Bestop version has - it's just a super clean, high visibility bimini.
This one fits like a factory product (no gaps, etc), installs super easy with clips and tightening straps, and has a premium build quality to it that you would expect from a brand like Bestop. The flapping at highway/freeway speeds is as minimal as I could imagine a bimini can be - definitely not terrible.
If you want to put your hardtop panels back on, it's pretty quick and easy to loosen the front two straps and the two bolts on the side grommet tabs (2nd pic below). You can actually roll the whole thing up and it fits between the rear hardtop cap and rollbar so you don't have to undo the rear straps and completely remove it every time. The only negative I found was with the hard plastic strap organizers that are included - I found those smack against the rear rollbar at higher speeds so I swapped them out for soft velcro strips which are easier to mess with anyways (see 3rd pic below).
I'm very happy with it thus far as somebody who wanted a simple, functional, and form-fitting bimini. It's a little pricey at $200 but I do think the quality/design is there to justify it.
