Homebowlking
Saint Albert Alberta Canada
2021 Bronco badlands
Specs: 4 door, Badlands, 2.7, lux, tow package .
Issue: Broken front passenger axle at CV joint. Repair was Ford replacement of both front axles. Will take 5 to 10 days to get the parts.
Update: I was in 4L and lockers were not engaged.
350KM after picking up my dream machine that took a year to arrive, it was on the back end of a tow truck with a broken front right axle heading back to the dealer for repair. The axle broke on a flat loose gravel parking lot at less than 5 km/hr with no load on it , while I was testing out (showing off) the 4 wheel cameras to my better half.
I have been a 4x4 enthusiasts for over 30 years and broken many axle as such I have learned not to full lock. The intent of the post was to see if this was an issue others have had. I am glad to hear it isnt.
Photos of break down and gravel parking lot that it happened and got towed from:
Ford Bronco Broken front axle at CV joint on my Bronco Badlands 4-Door 2.7L 2021-bronco-broken-front-axle-cv-joint-
Ford Bronco Broken front axle at CV joint on my Bronco Badlands 4-Door 2.7L 20210719_205410-
Ford Bronco Broken front axle at CV joint on my Bronco Badlands 4-Door 2.7L 20210719_205414-
EvlNvrDys
Hunterdon County, NJ
Specs: 4 door, Badlands, 2.7, lux, tow package . Broken front passenger axle, repair was ford replacement of both front axles 5 to 10 days to get the parts.
I'm gonna need some pics. Curious what actually broke.
Maybe this is why so many Canadians getting delivery now... It's the defective ones 🤷‍♂️
Sorry to hear it bud.
indio22
Chicagoland, USA
Auto or manual trans? Do you know what gear it was in (assuming low given the speed)? Was it the axle shaft that broke, or u-joint/CV (can't recall at the moment what Ford uses)?
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Shit happens. Every mechanical product breaks. I’m betting it was a one off. Sucks that it happened and I’m sorry about that. Ford will make it right.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Wouldn’t a happened if it was an SFA …
/ ducks :ROFLMAO:
NotApplicable
BEVs
What was the symptom
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
well it was the 2.7 so must be auto
Carolina Jim
Highlands
2021 Bronco 2-door
Mr. Nice
Jayson
Minnesota
12' Boss302, 08' Audi TT, 13' CRV, 14" Ridgeline
Sounds like Ford handled it the right way. You’re the first I’ve heard with any axle issues, hopefully it’s just a one off!
Hello? This is not good. The motor or transmission disintegrating would be better in my opinion. More parts to fail or assemble incorrectly.
Am I alone here?
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
I'm thinking not as loose of gravel as assumed......I have seen inferior parts on Fords but never a broken axle on something that wasn't abused......
Thank God I didn't order the cameras.....
