Can’t believe I waited for this peice of @&$!
rb1961
robert
ohio
f150
My 2023 has burning rubber smell often. Hoping it’s just something burning off and not trans etc. 400 miles so far.
Ford rep any info on this?
my brother had the same issue on his explorer , dealer told him, stickers on the catalytic converter causing the smell
Jruta
Nj
A51 Bronco 2 door
Other than the headlight issue (comes on by themselves out of nowhere- and the chime sound when it should not) no other major problems with it. I love it otherwise.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
My 2022 Badllands edition with less than 2000 miles just had the same issue with the start/stop problem yesterday. Was at a stop sign and the vehicle just turned off and didn't re- start. Completely locked out. It Started after a few minutes the first time, but it happened 2 more times on that day. The 2nd and 3rd time it didn't restart till 10-15 minutes later. Was over 100 miles from home..so happy it restarted and able to drive back. Called the dealership and scheduled a check up. Calling Ford to let them know that I'm having a problem with a brand new vehicle that never should have any issues, being it's not a first edition model. 2.5 engine.
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
OuterJersey
Honda, Toyota,VW, Lexus, Triumph, Honda MC
@Ford Motor Company i got MY2023 700 miles and zero complaints so far..Love it. Hope it stays that way! Just the burning rubber smell sometimes but guess that’s a non issue
rcornish4
Rich
Ford F150
New to the forums... I took delivery of my 22 OBX a month ago and have been extremely satisfied. Hope the folks with issues are in the minority and able to get resolution because these things are awesome!
Mikesmallcrawler21
TN
14 F150 screw
MAYBE LOOSE BOLT CONNECTIONS IN THE FUSE PANEL UNDER THE HOOD???
bomchet
Bom
northern va
2014 dodge durango
Sorry, just seeing this now -- but mine (22, OBX) had locking issues (it just wouldn't). Both the fob and the in-door locks wouldn't work.
They had to replace the ACM -- took em 5 hours to diagnose it. Since then, it's been perfect.
Garemlin
Delaware
October 10th delivery. So far I have had the following issues…..
-Service engine soon light. According to the Ford Pass app “Powertrain Malfunction /Reduced Power”. Had it in the dealer and zero code history.
-Got stuck in gear and would not downshift twice.
-Sync froze up twice. Once causing my phone to also lock up.
-Started blowing air from the vents full blast with HVAC turned completely off.
-Have some sort of fabric flapping sound from the soft top when the window is cracked. Have not been able to isolate it but it’s somewhere between the drivers side front and rear doors outside of the roll bar.
Bullitt
Colorado Springs, CO
2022 Bronco, 2001 Bullitt Mustang
Owned my Bronco now for about a year with 13,000 miles...couldn't be happier! Zero issues and miles of smiles!
jitsujohnny
Johnny
Latrobe
2021 ram trx, 2022 bronco
I have had the reduced engine power
Service 4 wheel drive
Service engine soon
A/c has broke
Low oil pressure
Now I’m in possible engine failure
And the dealer is giving me a hard time I’ll never buy another ford
604Bronco
British Columbia
www.bronco6g.com
Ford Bronco Can’t believe I waited for this peice of @&$! broncoswin
Is this what Ford meant when they told us to “hang in there?” If that’s the case, this looks like fun!
DrewPeakoc
Maryland, United States
2020 Toyota 4 Runner
I would search this forum for something about a bolt rubbing against a coolant line...
OuterJersey
I went to dealer for a check-up all good. Got to see this delivered too
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
Love my 22.. 12k no issues.
