BAUS67
redneck
Central PA
Almost done so I thought I'd start a thread.
Chopped up a bronco more-doors top and did some fab work. Got a few adjustments to make and a final sand and paint, but overall I'm satisfied so far.
The front two top panels still lock in place to the new half-cab the same way, and they are obviously still removable.
The Bronco top is nearly 3 ” narrower in the rear than at the B pillar,.so this presents a bit of an issue. Some massage is needed to make up for the wider B-pillar and get the rear of the old top to match up well with the middle of the truck.
I made sure I can still use my old MIC 2 top ... and I will add 4130
inserts to the roll bar at each end that can be bolted in with aircraft grade fasteners. The roll bar will be removable.
The original hard top is still usable and now I have two top options.
I will build a bolt-on bulkhead across the front of the bed that will match up with the bottom of the window. The window is the same, so the defrost, wiper and washer will all be functional.
The side curtain airbags did need removed, and I plan on installing a set from a 2dr F150 in the near future, as they appear to be installed in the same area and fashion.
I also ordered a new back roll bar cross support that I will build into a removable cross support while the half cab is installed.
Still have lots to do.
Bulkhead
Speaker pod mounts.
Tail gate
Tool boxes built into bed.
Here's a few pics of my progress. It's a bit dusty as I'm still sanding here and there.
Nice work.
andrusoid
Steven
Bend, Oregon
2017 Outback, '79 2G, '89 3G, '92 5G White!
Bulkhead
Speaker pod mounts.
Tail gate
Genius! You just went to #1. Many wouild argue that this is how the new bronco shouild have been made, along the classic platform with a topper behind. Pretty sure there was a lot of back and forth on the design team before they came up with the new model. Make sure to delete the metadata in your photos before I come and steal this out of your garage.
Super Scweet!!!
North7
North Texas
SUV
His Bronco, his money, his mods. If @BigMeatsBronco is smart enough to do this build he is smart enough to know about warranty and just doesn’t care. He took a new vehicle and made it better, now please take your mall crawler and go piss on someone else's parade.
MistaGavin
Alaska
'00 F-150 & '68 Mustang GT
Good work, keep it up! I think it would look nice with some kind of black protectors on the top of the bedsides.
Bronco Bob
Bay Area Ca
1977 Bronco, 1994 Bronco, 2009 F150, 2017 F 250
What did You use for the Bulkhead?
Beach_Bum
St. Augustine, FL
I can't think of anything more practical for a Bronco than a bed outside the cab....... propane tanks, gas cans, wet dogs, chain saws, grass clippings, minnow buckets...........
Also, plenty of room to carry Big Meat's massive sack of balls. Just slings them over his shoulder to enjoy the fresh air.
NotThatScott
Vashon Island Washington
2022 2D & 1958 Willys Utility Wagon
F A N T A S T I C! You are going to be the only one driving my absolute favorite Bronco Build. Congrats! Did I miss the pithy name in the thread? ...Like... "Bed-sy"? Or just "Steve" (as in Steve Caballero the famous skateboarder for whom the skateboard/snowboard "Half Cab" move is named).
Ford Bronco Half Cab Pick-Up Bronco Build! 🪚 1484050524609
