What's the lowest pressure you'll run for a given tire wheel combination?
What's too low, and what is the story of how you found out?
For the 34.5" Goodyear Territory, it seems the conventional wisdom is no lower than 20psi on a heavy vehicle like the Bronco. Goodyear itself has told people no lower than 29psi.
**UPDATE**
I pulled the numbers from the thread, and here is what I see so far after categorizing the feedback and just drawing the average, min, and max. I included the number of responses below, and higher than the average.
Generally, most people who reported why they lowered pressure it was for comfort more than traction. We had a report from someone that they used low pressures on their Diesel truck that was much heavier than a Bronco. And there were a couple of notes on how important it is to be careful of excess wheel spinning or pinching the sidewall when lowering the air and generally just driving smart.
It seems a couple of things are clearer now than previously.
If someone is running higher than 17 PSI because they are concerned about losing a bead, it seems you don't need to worry so much.
On rocky terrain or Fire Service Roads, you likely could get way lower for more comfort.
One last point, if you air down more, that does mean more time to air up; as someone pointed out, they actually upgraded their air system due to how long it could take to air up.
**UPDATE**
Average | Min | Max | |
Snow/Sand | 13.2 | 8 | 20 |
3 lower | |||
2 higher | |||
Rocky | 13.47 | 7 | 22 |
9 Lower | |||
8 higher | |||
Fire Service Road Average | 17.2 | 10 | 25 |
4 Lower | |||
5 higher |
