Yeah that's the thing. I've been wrenching on stuff for 35 years (damn that sounds bad) and the advances in computer controlled shifting and 6 / 10 speed automatics have made a huge difference when it comes to gears and bigger tires.Not nearly as big of a deal with a 10 speed auto that more easily keeps you in the power range easier
It’s at least 4k that’s why I’m on the fence. Because at this point it’s only for tires and wheelsI am not getting the BL but I thought it was only 2500 to add it to the BL .
No one mentioned that it is covered by the manufacturer's warranty as opposed to going aftermarket which will not be covered by the warranty. I also believe that 30 years from now a factory Sasquatch'd package will be more desirable than a modified Bronco.
https://www.intercotire.com/tire_size_change_gear_ratio_calculatorNot nearly as big of a deal with a 10 speed auto that more easily keeps you in the power range easier
More or less? Most likely less.It’s at least 4k that’s why I’m on the fence. Because at this point it’s only for tires and wheels
Then it's a good thing I'll have more power by running premium and a tune to compensatehttps://www.intercotire.com/tire_size_change_gear_ratio_calculator
I put in the following:
new tire size: 35
old tire size: 33
old gear ratio: 4.46
It calculated out the following:
new gear ratio: 4.73
The 4.73 x 35 ratio is what is needed to have the same final drive ratio from stock 33 x 4.46
Just trying to help you from my real experience switching from 31 to 33 without changing oem 4.10 ratio
having the 10sa is not going to help being under torqued at highway speed.
The overdrive in the 10sa will actually have the opposite effect and exacerbate the torque loss.
you could have just had mine, lol...them things coming off as soon as it gets home. I hate to toss them and was actually thinking of framing the window sticker in garage and will put one there.I’m getting Sasquatch for the cool sticker.
The two door looks great with 33's!If I had gone with another trim, I would have Squatched it. At the Austin Off-Roadeo though, the non-squatch BLs did everything the other trims w/squatch did no problem. Maybe others plan on more extreme off-roading than what the Off-Roadeo offers but they will probably upsize from the 35s anyhow. For me, a 2dr BL with the 33" KO2s is perfect.
It's beginning to feel like I'm trying to explain the meaning of life to one of my adult children.Then it's a good thing I'll have more power by running premium and a tune to compensate
If it’s purely for tires and wheels… I wouldn’t get the Sasquatch package. Go aftermarket and get something you love that’ll end up being more unique and different from what will soon be the overly common Sasquatch wheels. Option 2 is see how you like the 33’s and if you love the Sasquatch wheels/tires buy some take offs at some point. As more become available, the price will likely drop and they’ll be super affordable.It’s at least 4k that’s why I’m on the fence. Because at this point it’s only for tires and wheels
LOL, that's ridiculous. I find that the 10 speed transmission is not prone to putting me in a position to ever feel like my Bronco is lacking torque.https://www.intercotire.com/tire_size_change_gear_ratio_calculator
new tire size: 35
old tire size: 33
