2.3 & 2.7 Failed Turbo List (33 Counting Slowly Working on List)
telenerd
Laramie
Subaru
Let’s get a list started on failed Turbos!
Here is mine.
3miles - Failed waste gate then failed Turbo off dealer lot.
2022, 2.7 Engine/October 19 Blend
https://www.bronco6g.com/forum/thre...new-bronco-turbo-waste-gate-stuck-shut.58475/
Jonny Bronco
2.7 Engine, 2022
https://www.bronco6g.com/forum/thre...sasquatch-blown-turbo-2-7.55266/#post-1674517
Myfaux
2.3 Engine, 2022
https://www.bronco6g.com/forum/threads/2-3l-what-happened.53315/#post-1576942
2.3, Banned Member
https://www.bronco6g.com/forum/thre...-behavior-by-op-others-bans-instituted.47080/
BadBradBronco
2.3, 2021
https://www.bronco6g.com/forum/thre...turbo-2-3l-engine-failure.42655/#post-1382687
FirstFordSince1984
2.3, 2022
https://www.bronco6g.com/forum/threads/manual-shift-2-3-turbo-doa-after-300-miles.45400/
BamaBronco98
2.3, 2022
https://www.bronco6g.com/forum/threads/bad-turbocharger-after-70-miles-2-3l-manual.38826/
Bbj BroncoIV
https://www.bronco6g.com/forum/thre...gate-bypass-valve-needs-to-be-replaced.56816/
Schllip
2.7, 2022, Waste gate failed
https://www.bronco6g.com/forum/thre...ing-to-service-department.54414/#post-1637404
DMorty217
https://www.bronco6g.com/forum/threads/what-did-you-do-to-with-your-bronco-today-👨🏻‍🔧🧰🚿🛠.18089/page-230#post-1594558
Kmumm01
2.3, 2022
https://www.bronco6g.com/forum/threads/5-2-22-build-week-group.38770/page-131#post-1430273
Beetuff33, tjksmitty, fuzion2bronco, reddawg, gja&z
https://www.bronco6g.com/forum/threads/new-turbo-needed.42976/#post-1378968
Toddlabqq, turbony, lokki444, thecaseyd, gopre, velocitybronco22,
https://www.bronco6g.com/forum/threads/bad-turbo-wastegate-at-100-miles-2-3l.40523/
Yurrty
2.3
https://www.bronco6g.com/forum/threads/powertrain-malfunction-at-150-miles.41167/
Opticalnerve19
https://www.bronco6g.com/forum/threads/🛠-1-17-2022-build-week-group.28746/page-777#post-1505181
Bayard , bmisk19
2.3, 2022
https://www.bronco6g.com/forum/threads/2-3l-turbo-boost-issues.38556/
Shanna
https://thebronconation.com/general...f-their-new-bronco-and-it-was-broken-t.11266/
Citybronco
See below post.
Robins26
See below post
Juliet
See below post
23WildtrackAgm
Sunday Money
ZIA07
telenerd
telenerd
Laramie
Subaru
Slowly working on list from members. If you have a story post!
telenerd
telenerd
Laramie
Subaru
Dam this is taking forever. I’ve barely scratched the surface of reported turbo and waste gate failures in Bronco6g. If anyone wants to add to post please do I will update the count!
I’m estimating the number is higher than the reported engine failures on Bronco6g.
da_jokker
Jeep Wrangler JKUR
If that's the case you better start collecting build dates (specifically engine builds) because that's what's going to make the difference If there's a trend or batch or whatever.
telenerd
telenerd
Laramie
Subaru
Good idea. Wanna volunteer for the cause? Or anyone else wanna volunteer? Maybe a spreadsheet might help. The guy that built the fancy build week sheets might be able to help. I will pm him.
Robbins26
Tyler
Virginia Beach
2015 F150
Just pick up my 2.3l manual. Same thing Bad Westgate on the turbo after 15 miles on the bronco leaving the dealership....
telenerd
telenerd
Laramie
Subaru
Sorry to hear. My guess it’s the waste gate actuator, which is a fairly easy part for the dealer to replace.
I have the list updated now.
JulieT
Julie
19 Ford Explorer, 23 Ford Bronco
Add another to the count. 2023 2.7, Engine light and wrench light came on at 8 miles when the tech was almost back to the dealership during PDI drive. Bad drivers side turbo.
telenerd
telenerd
Laramie
Subaru
List updated. Thanks
