Not when it's a designated crumple zone.See if they’ll bend it back and get it reinforced. Also, FFS you should be able to back into rocks and not destroy your frame.
3,340 to 4,500 lbs tow rating and put a crumple zone right at the hitch. I seriously do not think so. That would be mind boggling stupid. I can see the crumple zones in the frame picture.Not when it's a designated crumple zone.
I believe it hitches can cause unexpectedproblems, some years ago I had an old-style boxy Ford Escape. I had a local shop install an aftermarket 2" receiver hitch on it. Year or two later, was rear-ended by a (Phillies Game) drunk driver on I-95 at speed. Car was drivable, but I wasn't! Insurance totaled the car and paid me off. Auto Body shop said the car would have been repairable if not for the hitch! Said that the leverage caused by the hitch being hit, caused unrepairable damage to rear floor pan/frame! I think about that when I drive around with my bike rack, or Kuat Pivot alone!UPDATE: Here's info from @flip regarding replacement frames now available:
Per @flip - https://www.bronco6g.com/forum/thre...cking-into-a-creek-boulder.52372/post-1560288
If this would've been 6 months ago he would've been totaled. There are a couple dozen of these at the depot in Detroit. I don't know if the service procedure requires the body to come off or just the bumper but better this get trashed than one of the rear rails. The part with the green triangle (rear subframe section) is also available. Front section (out of pic) shows 1 in the warehouse for the 2.3 and 1 for the 2.7. Looks like there are one or two full frames now available as well so if you get side smacked with frame damage, it may not total due to part availability.MB3Z-5F146-A
ORIGINAL POST:
What had happened was I left a hitch on the Bronco and backed into a boulder in a creek. We need not recount how many dumb ideas I had this weekend, but rather look forward at the ramifications. The frame is real real bent. Other than being ugly and moving my hitch an inch or two towards the body, what other problems might this cause if I don't have a body shop fix it?
As I remember, thats a "special" steel, dont know how that affects repair or weldingNot when it's a designated crumple zone.
Are these welded in as a subframe piece? I haven't seen a side-by-side of Bronco v Braptor frames.Raptor braces won't work on non Raptors unless the muffler is removed. I've not put hands on the braces yet but don't think they provide much in the way strength. Mainly there to take some of the flex/twist out of the hitch and crossmember when towing a heavy load.
I have a few raptor hitches and they have two 8 or 10mm holes drilled in the bottom with nuts welded on. The braces appear to just be bolted to the hitch then a couple bolt to the frame. Since they attach to the bottom of the hitch the only thing I can think they do is keep the hitch from torqueing/twisting when pulling something heavy.Are these welded in as a subframe piece? I haven't seen a side-by-side of Bronco v Braptor frames.
I would think that’s accurate and reasonableI have a few raptor hitches and they have two 8 or 10mm holes drilled in the bottom with nuts welded on. The braces appear to just be bolted to the hitch then a couple bolt to the frame. Since they attach to the bottom of the hitch the only thing I can think they do is keep the hitch from torqueing/twisting when pulling something heavy.
I don't know all of the upgrades they made to up the towing capacity but it seems like they're aware of the flex between the hitch and the crossmember so they added the strut bars. My guess is the biggest piece was the addition of the additional OTA trans cooler. Might be some rear spring upgrades but haven't dug enough to see if those are unique to raptor or one they're already using on a tow package.I would think that’s accurate and reasonable
I also note most people disregard the rear suspension squat when towing on the bronco
CG shift is huge on braking/handling
If you look at how the receiver mounts, it isnt hard to see how having a hitch in the receiver and hitting something solid could torque that crossmember.Had to be or faster. Just did that with my Gladiator into a tree backing up. Looking at clearing a rock and was being stupid. Was a jarring stop but no damage at all to the rig. Tree has a new tattoo. If a Bronco cannot take a hit to what should be one of the most solid parts on the vehicle at 5 - 10 mph then Ford should repair this on their dime and use it as a learning tool and fix it. That is seriously unsafe and a huge issue.
The Flowmaster High Clearance Axle Back exhaust is essentially a straight pipe, pull the muffler and it tucks right in. 10 minutes to swap before an off-roading trip, it's loud, but it doesn't sound bad. Only $135, routes the exhaust all the way back, and it looks good too.A few things here.
1. This is exactly why I opted to not get the tow package. That receiver will likely be the first thing that hits in any situation and you lose departure angle.
2. On my Dad's FJ Cruiser we actually cut this rear frame member out and moved it towards the front a couple of inches to help with that. Fully aware that doing so could change how the vehicle reacts in a crash situation. We didn't think it would be too much of a risk (looking back he probably should have made the dealership aware of that when he traded it in........).
3. Where is your muffler? Is it a thing to cut the muffler off on a Bronco? Don't get me wrong, I've ran straight pipes on several V8s, but never of a twin turbo V6....
