MoabRox
Two Jeep XJs, Dodge M880, Suburban 2500
HalfNHaff
Ethan
OkiCaliHaw17!@
4Runner
Does anyone have photos of the 5100s installed with 33” tires? If so, please post it and share the lift settings you used. I’d prefer to have 33” vs 35” because it’s a daily driver but I also don’t want it looking like the tires are too small for the lift. Thanks in advance!
Ctholl
Casey
WY
Jk wrangler (bronco on order)
Nice ride!
Ford Bronco Bilstein 5100 adjustable lift shocks installed. Before & after pics (updated with Wildtrak tires & wheels) PXL_20230101_194453183
Keith Baker
Winter Haven, Florida
2022 Bronco
Looks awesome! Thank you for sharing.
How’s the ride? Any difference + or -?
The ride is definitely firmer, but it rides good. I couldn't decide between 2" and 1.5" so my wife made the decision. Her Bronco has a 2" spacer lift with take off sasquatch wheels and tires. Now mine dosen't look near as bad when I park next to hers. I drive my every day for work and the 33" are giving me around 21mpg. Overall I'm happy with the way it came out.
Ford Bronco Bilstein 5100 adjustable lift shocks installed. Before & after pics (updated with Wildtrak tires & wheels) image (7)
dgorsett
colorado
F250, Mustang, Explorer
5100s installed on non Sas 2 door with 265/70X17 set at 1.5 front and 1.75" rear, loving it
Ford Bronco Bilstein 5100 adjustable lift shocks installed. Before & after pics (updated with Wildtrak tires & wheels) 20230112_171910
Ford Bronco Bilstein 5100 adjustable lift shocks installed. Before & after pics (updated with Wildtrak tires & wheels) 20230112_142617
Ck17466
Collin
Ford Bronco Black diamond
I love this look. With all that being said. I bought some Bilstein takeoffs from a 2021 bronco 4 door wildtrak edition and wanted to install them on a 4 door base black diamond. Should I be ok or would I have any issues. Also, in addition to the new shocks on the black diamond could I also install 2 inch spacers along with the Bilstein takeoffs and have no issues? Thanks in advance for any advice and hep on this
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
how hard is it to change the Circlip Location after the 5100s are installed? I will want to switch to 35s when my 33s burn out and will want to up the lift at that time.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
They will have to come off and be taken apart.
Ck17466
Collin
Is there a reason you didn’t move these to the highest setting. Circle clip 5. Thanks
Justin
I have no regrets at 1.5". I'm running 285/70/R17 Falken AT3Ws and think the wheel well gap is just about right. With 265/70R17s, it might be too much. Although the picture doesn't show it, it has the factory rake which I like. I've never understood the obsession for leveling--throw a cooler and some gear in the back and you're squatting. The extra clearance makes a significant difference and wheel travel increased too! There's still nose dive when braking but it's not a bad as before. I'm surprised that with the winch your Bronco is still level, and it doesn't seem right that one front side sits that much lower than the other. Have you had anyone look at it?
This is exactly the look I am going for. Which Circlip did you use?
