Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.I have noticed this noise as well since the temps have dropped in the morning. The noise is present with clutch pedal released in neutral. Noise goes away after clutch depressed or when vehicle warms up. 2200 miles on my base 2 Dr. I was a Ford tech 20 years ago and now I teach high school auto tech. This is not a throw out bearing issue as it's not rotating with clutch not depressed. Maybe a change in fluid viscosity may be the cure since it's cold engine related. My students and I have investigated the noise and seems to be coming from the transmission.
