U725Bronco
NorCal
@Gloff think this is worth having the techs at Serramonte add this to the PDI checklist?
Brad Fx
U.S.A
Jeep Commander
@crummer I'm not sure how you got that pic/angle, it’s a bed of snakes in there. I can barely see the belt and pulley.
Boxer4
TRUCK
2.3BigBend
PA
Work Beater
Glad I ordered the 2.3L. My dealer would likely deny the warranty claim because I "modified the cooling system" if they found a zip tie on there preventing a catastrophic failure.
Because of a problem that can be fixed with a zip tie and a flashlight? Umm.
It's called sarcasm. Making a joke out of what the dealer would do if they saw I had fixed Ford's failure. Sorry that went over your head.
acnp2022
CT
ford
How were you all able to get your hand down in there to zip tie it down? It’s a very tight space.
It's easy to get your hand down there on the right side right by the fan. Where people were showing it originally it's impossible to get your hand down there. I kinda give an idea on the previous page, but it's hard to get a good pic
U725Bronco
NorCal
Not unless an FSA or recall is issued.
Fair enough....I only brought it up because I saw @flip said he told his PDI folks weeks ago to check for this and add the zip tie if there was contact. He also said he put it on the Ford message boards. I suppose if this is a big enough problem they may issue an FSA or recall. I'll try to remember to check my Bronco when it comes in.
Gloff
Sean
San Francisco
www.serramonteford.com
'21 Ford Bronco Big Bend, '03 BMW Z4
We do keep an eye out for stuff like this and pass it to Ford. Ford has a system for concern reporting.
jd-ford-hd
Tennessee
‘16 Explorer, ‘13 F150, ‘99 F350, '74 Bronco
Can you just imagine what the engine bay would look like if we had our dream engine, the 5.0 Coyote, stuffed in there.! I’d like to see.!
timgarrett
Tim
Currituck, NC
1997 F-250
Mine wasn’t rubbing and had about 3/4” clearance. Still went ahead and tied it back like the others. Was a minor pain in the ass.
JediMcMuffin
Tommy
2021 Bronco Badlands
Mine has plenty of clearance. Badlands which came off the line first week of September. There also appears to be some kind of retaining strap about two inches wide wrapped around the tube
CPTRK
Patrick
Weston, FL
Jeep Grand Cherokee
Yep on mine the hose sitting right up near that pulley nut. No signs of wear @ 200 miles but I zipped her up. Long zip tie from front by fan helps to reach. The clip ...
Raptor18
2020 F-250 Tremor, 2021 Bronco
I was able to get a 14” tie around both of the lines tied to the turbo plumbing, the two smaller lines really flopped around. Attached is a pic with the camera further away to shoe the battery and location of the zip tie added. The circled line is the trouble line.
Ford Bronco PSA for 2.7 engine: check belt pulley nut for contact with coolant hose 02BB51B4-4AA8-4DF4-A8CE-D3C7BF42F965
