BroncoT
SUV
Has anyone added a 7 pin connection? Is there some reason that’s so much more difficult. I canceled towing to get my Bronco sooner (it worked) and don’t need it at this time. I’m considering a jet ski or boat though and would rather spend a bit more money/time to install a 7 pin, even though it’s likely overkill.
Initially I’ll just bolt on the already ordered hitch for cargo and bikes. Wiring would be more of a summer project.
spyderman01
Joseph
Satellite Beach, FL
Ford Maverick
I would add to that statement: If I have the need for 7 lines and trailer brakes in the future I can always add it. People have been adding aftermarket trailer brake controllers to Trucks and SUVs for decades. It would just take some extra effort.
Exactly, I had my BMW X3 wired up for a 7 pin. Though it was easy since the battery was in the trunk so that line was quick, then for the controller I just had to run another wire up to the front and there I hid it under trim. It just takes a little bit of work and yes, not as easy as just plugging in the harness like I did on my Jeep.
My 1900 TT has electric brakes, and while I can get away with not using them, why not use them if they are available?
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Yes, and I would argue that most towing less than 3500lbs won't need a 7 pin.
I need a 7pin. Plan on getting an off-road camper like the Patriot Camper X3.
Denny3297
Denny3297
Dennis
Wisconsin
Acadia, Ranger, Fusion, E450 motorhome, Focus
Then by all means, add the 7 pin. There were plenty of them available in the aftermarket. I just chose the 4 pin for my needs.
1stBroncoBase
Iowa
2022 Base Bronco (Ordered)
Hello, I thought I'd share my tow package build. I have not looked for a similar post so apologies if it's a repeat. But here is my self made Tow package. I removed the factory tow package to hopefully get built quicker, and it worked. Here is my parts list, and a quick install review:
Parts:
1. Curt wiring kit p/n: 56468 - $79.82 (etrailer.com)
2. Curt Receiver Hitch: 13493 - $104.31 (toysfortrucks.com)
3. Wiring Connector: Road Tough - $16.89 (Amazon)https://www.amazon.com/Road-Tough-W...ix=road+tough+trailer+connector,aps,79&sr=8-1
Total: $201.02
Savings over Stock: -$393.98
Hitch install, easiest I've ever done. Seriously. It took less than 15 minutes.
Wiring, was relatively easy other than the Wire running to the battery. Had to get creative on that one.
Total install time: 2(ish) hours.
Conclusion: I got my Bronco early, and saved $400. Totally worth it.
Thank you for sharing. I went out to look at the hitch and found something interesting, this should fit a 2022 base bronco right? It fits a 2021...
VEHICLE FITMENT
Fitment: No
  • Year: 2022
  • Make: Ford
  • Model: Bronco
  • Body Type: Sport Utility []
  • Sub Model: Base []
VEHICLE FITMENT
Fitment: Yes
  • Year: 2021
  • Make: Ford
  • Model: Bronco
thehermdawg10
Clayton
Temecula, California
Toyota Tacoma, 1985 Toyota Corolla GTS
This is probably the best solution for me, as I’ll probably only ever use the hitch for a motorcycle carrier. Thanks for the info 🤙🏻
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
VEHICLE FITMENT
Fitment: No
  • Year: 2022
  • Make: Ford
  • Model: Bronco
VEHICLE FITMENT
Fitment: Yes
  • Year: 2021
  • Make: Ford
  • Model: Bronco
Yes, should be the same for 2022. Where did this fitment info come from?
Denny3297
Denny3297
Dennis
Wisconsin
VEHICLE FITMENT
Fitment: No
  • Year: 2022
  • Make: Ford
  • Model: Bronco
VEHICLE FITMENT
Fitment: Yes
  • Year: 2021
  • Make: Ford
  • Model: Bronco
I have a 22 Badlands and it fit fine. I'd check the Curt website directly. Or maybe even call them.
1stBroncoBase
Iowa
Herbie
Alex
Cleveland OH
2022 Badlands
CentralFLBronco
Jordan
'22 Bronco Big Bend
Denny3297
Denny3297
Dennis
Wisconsin
Agreed on that one. Could even celebrate with a bottle of some single barrel JD!
I'm more of a Blanton's guy myself, but yes. I'm happy with the result!
vrtical
Doug
GSMNP, TN
Fords
Ford Bronco Self Made DIY Tow Package (If 7-Pin Not Needed) 1643995492333
BamaBronc
7/19 Purgatory
www.google.com
F150 and Edge
Denny3297
Denny3297
Dennis
Wisconsin
