Steering rack bushings cheap options and alternatives. Reviews pending!
mcinfantry
mcinfantry
Lee
Louisiana
Badlands 2 door
Oetiker clamps are ideal for clamping rubber oil hoses because they maintain clamping force through heat cycles better than worm-drive hose clamps. Standard worm-drive clamps can't expand as the hose assembly heats up and, therefore, force the hose material to extrude away from the clamp area during a heat cycle.
OETIKER Stepless low profile clamps are reusable. They can be opened and installed time and again, for example for maintenance and servicing in the automotive industry and they can also be installed both axially and radially.
So I guess they are allowed to be reused
da_jokker
Jeep Wrangler JKUR
I ordered some 3/8” band width hose clamps from Belmetric.. should fit perfeclty
They may but that is larger (.375) than the 7mm (.275) clamps that come off.
da_jokker
Jeep Wrangler JKUR
For you wrench geeks I'd love to see a wheeling trip then an inspection on how they held up. Probably asking too much lol
Will it depends on what you mean by inspection. Removing the rear hose clamp and sliding off the boot to look would take 5 minutes.
Removing the bushing to actually inspect for wear .... You'd probably have to destroy the bushing to get it out.
da_jokker
Jeep Wrangler JKUR
I second this.
Another naive question that BB mentioned and I wasn't sure on - is the black protective spacer inside the rack body that he recommends breaking to remove already shaped like the bushing he / RC sells? Is the bushing for sale just a solid version of what's already in there just more supportive and tighter ID?
If you were to hold that black factory spacer in your hand You would realize it has no structural integrity. It fits loose in the case and is basically just a guide (It almost reminds me of throw away padding that sometimes you find in a shipping box used to prevent the merchandise from banging on each other).
The delrin parts are actually bushings that provide strength like a "sleeve" that goes around the steering rod and provides a support brace that distributes the torque to a wider surface area.
broncorik
But they clamp in a range
when you squeeze the end it has to be a range
At least that’s how I understand it even from their own description it states range
I ordered a few
I’ll follow up
Let me know...I prefer OEM versus the "one size fits all" kit all day long. From the Oetiker reference:
Ford Bronco Steering rack bushings cheap options and alternatives. Reviews pending! Screenshot_20230425_085454_Chrome
da_jokker
Jeep Wrangler JKUR
Yep… so?
Oh I just brought it up because we are talking about having clamps the correct size that fit in the groove instead of smashing down that outside lip.
It'll be interesting to see if 3/8 wide clamp actually fits in between those lips because I didn't look to me like there was a 1/8 inch to spare.
But let us know! I would swap out my hose clamps for a narrower one that I know works.
V1Rotate
Brevard, NC
2022 Wildtrak
I’ll report back.. they should be in soon. Figured a smaller band hose clamp would work better for me than replacement OE clamps because they’ll be infinitely reusable.
Tex
Cliff
San Angelo
Any reason why we couldn't use a more conventional constant tension clamp, such as a Murray or spring type? I'm a big fan of both and I used them in every application I can before I go for a conventional worm drive clamp. Those Oetiker clamps are a pain in the ass.
mcinfantry
mcinfantry
Lee
Louisiana
Badlands 2 door
I don’t see why not.
da_jokker
Jeep Wrangler JKUR
BroncoAg
PA
Bronco Sasquatch
I just ordered this DIY kit off Amazon. The above is similar but is 7mm and needs to be crimped instead of using a worm gear. Seems like this should be good enough but does require a little fiddling to get the size correct if you prefer to be able to keep the extra band length trimmed down.
https://www.amazon.com/Swordfish-80050-8mm-Width-Stainless-Steel/dp/B07CQ4BF39
HANG ON Y'ALL I STARTED MY OWN COMPANY. This is A PROBLEM in the COMMUNITY and THEY!!!!!!!! don't want YOU to know about IT! BUY MY CV clamp kits and WE can solve this!
BAUS67
redneck
Central PA
Why not use something like this????? Don't have to worry about the right size clamp with this. ;)
https://clamptitetools.com/
And not stupid expensive. 😁
